for those with fiberglass hard tops and SW doors - Defender Source
Old September 21st, 2015, 02:29 AM
defender1844
Amit Likhyani
does that combination seal better than the soft top door plus sliding window? I'm wondering if the issue is the 2 piece doors on the soft top and flex at the top or if it's the seal on the fiberglass top.
Mit
Old September 21st, 2015, 02:43 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Door seal, no matter what you run, is a bit of voodoo. It's dependent on door alignment, tub-to-bulkhead alignment, top alignment, gutter alignment, etc. if any of these are misaligned, you may get leaks, a sticky door, a difficult-to-open door, or a door that pops open while driving.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old September 21st, 2015, 07:14 AM
It's your doors. There's a good thread on the subject by JimC if you search threads by him.
Old September 21st, 2015, 09:05 AM
I've never had major problems with door tops fitting badly, and the technique I've described somewhere using strips of pond liner helps tweak the fit between the top and bottom. I've heard of people having more serious problems and actually hooking their door tops to the visor to hold them in. That was described here in a super old tips post. I think that's a bit much though an snakes me think something more significant was messed up.
Old September 21st, 2015, 09:10 AM
Also two things:
SW doors almost always seal better.
Do you have one-piece seals on your hard top? (There should be) if so, how is the transition between the body and the top - this needs to be as continuous as possible for the seal to bridge the gap nicely. A picture of your door jam and door seal would help a lot.
Old September 21st, 2015, 01:30 PM
defender1844
Amit Likhyani
I had a 1997 with the fiberglass hard top and I was OK with the door seals. Didn't understand that complaints. I actually really liked that top.
I've got a 1995 now with only the Rover's North top and I haven't even tried driving it with the windows yet. If I get another fiberglass hard top I'd probably have to repair it and paint it body color at which point it may be justifiable to get the SW doors and get those painted as well. It's not the door seal I don't like about the sliding windows it's the sliding windows and lack of place to put my left arm.
It's mid to late September in Austin with the temps still in the mid 90s but it will eventually be roof season.
door, fiber, fiberglass, glass, hard top, top
Pre Summer Exmoor Trim USA Top Sale (Mesh UV Tops, Surrey Tops, Bimini Tops) ExmoorTrimUSA The Vendors Loft 6 June 9th, 2017 04:26 PM
2 brand new fiberglass hard tops Campbell For Sale - Parts 1 February 18th, 2011 07:01 PM
SW Rear doors / Series Lower doors and tops SafariHP The Vendors Loft 1 September 22nd, 2008 01:06 PM
Painting Fiberglass Hard Tops NashvilleRedD90 Defender Technical Discussions 20 November 7th, 2007 01:23 AM
Fiberglass Hard Top / ST / SW Doors other itmes FS SafariHP For Sale - Parts 25 October 10th, 2007 09:40 AM
