? for ST owners. - Defender Source
Old October 31st, 2004, 10:44 AM
mlw911
Michael Walter
1995 D90 ST
? for ST owners.
When closing the front doors, does the rear of your sliding window rest on the soft top pad that comes down behind it, or does it slip inside of it when closing? It looks like the door has been designed along the top edge towards the rear of the door to allow it to be closed on top of the soft top for a somewhat better seal. It's difficult to explain what I am trying to say but hopefully someone will get he gist.
Old October 31st, 2004, 11:26 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I think I know what you are asking. Yes the top of the door is supposed to fit up against the top. As most of our tops have shrunk there might be a little bit of a gap. I have about a 1/4 inch gap on my top.
Jimmy Buffett
Old October 31st, 2004, 05:26 PM
mlw911
Michael Walter
1995 D90 ST
Thanks. I am actually talking about the rear of the window and the edge of the top that runs down the side from the topof the car. It seems the soft top side actually can be closed (pinched) in the door when closed to create a slightly better seal. I need to know if this is wrong and may be causing damage to the top. I looked at many pics on ebay and can't figure it out.
Old October 31st, 2004, 07:42 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
When it's cold and there's a gap between my window and the top (no matter which part) I just put some black 1" foam pipe insulation around the top. It'll add a little space to give you the seal and it won't damage your top. The foam has a little bit of adhesive on it and it'll keep it in place.
"It's not a Jeep"
Old October 31st, 2004, 09:15 PM
thelandroverguy's Avatar
thelandroverguy
Vince
1997 D-90 ST
On mine I adjusted the metal bar outboard. The bar I am talking about is the one that attaches to the top of the tub, right behind the door. It also hooks itself to the top of the bar which goes across the door. This causes a good seal. I have no gaps or spaces when the doors are closed. I hope that helped.
Old November 1st, 2004, 03:35 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
Not sure what you mean on this. Here is a pix of how my doors close (note I did not use seal).
Name:	door seal 1.JPG
ID:	1805   Click image for larger version
Name:	door seal 2.JPG
WTB: 1997 Defender Owners manual pmd Wanted 1 March 27th, 2006 10:49 AM
Hey D90 Owners Discrover Misc. Chit-Chat 7 March 8th, 2006 11:55 AM
Owners Manual for '97 SW chrisvonc Wanted 2 November 23rd, 2005 03:47 PM
1997 Owners Manual Kimos Wanted 0 December 2nd, 2004 11:42 AM
Owners / Members In Georgia Kimos Defender Technical Discussions 0 November 30th, 2004 12:06 PM
