Footwell Replacement - Defender Source
Old October 30th, 2012, 03:14 PM
Holiday's Avatar
Holiday
Ross Simpson
1995 D90 ST/2006 D3 HSE7
For those of you who have repaired/replaced the rusted footwells of your truck (thanks to the OEM acoustic foam (sponges) that were placed under the rubber floor mats)- how did you do it?
The only concentrated rust area I have on my truck is in the footwell area, and I aim to replace it to prevent any further water intrusion. Already have the floorboards out (man that was fun).
Can the Rovers North or lucky 8 footwell kits be properly installed without a full bulkhead removal? At a minimum, it looks like the air conditioning under dash needs to be removed, as well as the driver foot pedal bolts.
Hoping to find someone local who could take care of the welding for me.
Thanks!
Old October 30th, 2012, 03:23 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Thanks!
The short answer is yes they can be repaired in situ depending on the extent of the corrosion. the challenge is sealing it all back up/paint with everything in place.
I havent used the luck8/RN panels but we stock YRM shapes and they are an easy weld in.
Old October 30th, 2012, 03:31 PM
Holiday's Avatar
Holiday
Ross Simpson
From the look of it- I'll need to replace:
LH/RH Outer Floor Panels
LH/RH Inner Floor Panels
LH/RH Outer Kick Panels
LH/RH Inner Kick Panels
In order to completely rid the area of rust, yes?
ID:	59998   Click image for larger version
Old October 30th, 2012, 04:13 PM
61rover's Avatar
61rover
John Crouse
That's not rust. I can put my arm through mine. Lol.
Old October 30th, 2012, 04:38 PM
x2 well I can't put my fist through mine, but that is not bad. I would just patch and mitigate.
Old October 30th, 2012, 04:45 PM
Put an abrasive brush pad on an angle grinder and go to town. You will get rid of the rust and it will look 100x better
Old October 30th, 2012, 04:46 PM
Holiday's Avatar
Holiday
Ross Simpson
I wouldn't call it "good"...! The bulkhead itself is in terrific shape, the only flaws being the footwells. This is the reason I've been leaning towards replacing the footwells instead of waiting to replace the entire bulkhead.
Raptor coating the seat box and cargo area, so the floorboards had to come out anyway. Figured this was as good of an opportunity as I'd have.
Unfortunately there are no repair panels that I know of that faithfully reproduce the originals. For that you might as well pop for a complete new bulkhead.
Old October 30th, 2012, 04:50 PM
Holiday's Avatar
Holiday
Ross Simpson
Only issue is- there's a two inch hole in the driver's side that allows rain water in when driven. I'd have to patch that and then repaint everything. Thought the full panel replacement would result in a cleaner finish.
------ Follow up post added October 30th, 2012 01:57 PM ------
That's my fear. Heard good things about YRM products, though. If the general consensus is to patch and paint, I may give it a go. I just don't have time to mess with it, and prefer to get it done right the first time-- thought the panel replacement was the right choice, and relatively speaking- it's not much money.
Old October 30th, 2012, 07:16 PM
YRM stuff is just bent sheet metal. It may measure out the same as the original but it looks like you made it yourself.
ac, footwell
Footwell Trim Replacement 61rover Defender Technical Discussions 10 November 20th, 2007 12:57 AM
Clutch replacement difficulty? Trigger Defender Technical Discussions 3 July 25th, 2005 03:18 PM
Replacement Speaker w/ stock grille??? swm9476 Misc. Chit-Chat 0 April 1st, 2005 09:55 AM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
Replacement Headlamps tuko Defender Technical Discussions 4 November 18th, 2003 09:51 PM
