Footwell and Door post repair: plan of attack? - Defender Source
Old October 9th, 2014, 11:05 AM
toad's Avatar
toad
Cutter
I'm going to be repairing my footwells and door post bottoms on my '86 110 and I'd appreciate some advice from those who have gone through this. I'll be using the YRM footwell panels and a set of door posts I got from RN, and doing the work with the bulkhead in place on the truck. I'm debating the order of repair for ease and alignment; cut out the footwell and tack in place then chop the door post, vice versa, or all at once. I repaired the footwell on my series but didn't have to deal with anything structural.
Also, not sure if I need to worry about support when I remove the door post, seems like the b pillar would take up the slack.
Old October 9th, 2014, 11:11 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
this may help for general reference
Old October 9th, 2014, 12:34 PM
toad's Avatar
toad
Cutter
Thanks, fun to watch, bolting new parts together make it look so easy. No headaches there. Not sure it provides much insight into cutting and welding but fun never the less.
Old October 9th, 2014, 12:36 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Figured it might clarify supporting structures and squares on the truck if you're going to be doing surgery
Old October 9th, 2014, 12:39 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
You will be replacing it all at once because the footwell connects to the upright. It's a major pain when the bulkhead is off the truck, I can't imagine how it works in situ. You will need to support the bulkhead because you will be removing the mount on the side you are replacing.
If I was to do it again, I would consider sourcing a bulkhead and complete the repairs, then have it galvanized.
Old October 9th, 2014, 09:33 PM
toad's Avatar
toad
Cutter
Yeah I don't expect it to be easy, I'm expecting to have to pull the pedals and have plenty of cursing working in tight quarters. I have the seat box out which will give me much more room inside, which is what I did on my series. Keeping the bulkhead on the truck should help a bit with alignment but I'll throw a brace of some sort on the upper bulkhead to ensure it doesn't sag when I remove the post.
Old October 12th, 2014, 09:09 PM
akrockhound's Avatar
akrockhound
Jack
1988 RHD 110
I did my footwells recently
I recently did my footwells but did not touch the A post.
I will attach some photos and you can PM me or call 907-590-9332 if you want to talk about it.
I used the YRM "short" footwell replacements. Under Advice from Ed Angel I cut out the bad panels and then installed the YRM's with about 1 inch overlap with the existing bulkhead.
So in my case it was the floor and a few inches up the sides and front of the floor (flat) section that had to go.
I used small self tapping screws to get the exact fit I wanted with the new YRM pieces and the I used rosette welds to make it permanent. I used 3M-5200 adhesive sealant to make it all water tight. Finally at the suggestion of another local who has completely rebuilt his SIII I used "peel and seal" as caulking when in put the floor floor panel and tunnel. This stuff comes in tubes like caulking, is clear and waterproof but comes back off easy if you ever have to get back into your tunnel or unscrew your floors again. For me it was a time consuming job but not particularly challenging.
Name:	IMAG0933 (Small).jpg
ID:	104867   Click image for larger version
Name:	IMAG0771 (Small).jpg
Name:	IMAG0830 (Small).jpg
ID:	104869   Click image for larger version
Name:	IMAG0963 (Small).jpg
Name:	IMAG0956 (Small).jpg
ID:	104871   Click image for larger version
Name:	IMAG0978 (Small).jpg
Name:	IMAG1005 (Small).jpg
ID:	104873   Click image for larger version
Name:	IMAG1023 (Small).jpg
Name:	P1020871 (Small).JPG
ID:	104875   Click image for larger version
Name:	IMAG1031 (Small).jpg
'88 ROW 110 5-door SOLD
'01 Disco II
'95 RRC LWB
Old June 2nd, 2015, 09:39 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
You mind if I text you when I do mine? Perhaps iPhone FaceTime action? I might be doing mine within the next 30 days. Awesome thread.
Old June 3rd, 2015, 12:43 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Steve, Brian at Defenders northwest carries the yrm 3 piece footwells
Old June 3rd, 2015, 01:21 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Thanks. I bought them. I may need a tip or two when doing the project.
Old June 3rd, 2015, 01:24 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Old June 3rd, 2015, 12:17 PM
akrockhound
Jack
1988 RHD 110
Yes you can call me
Call me if you want to discuss before or when you get into the job. 907-590-9332 Jack
'01 Disco II
'95 RRC LWB
Old June 3rd, 2015, 05:07 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Awesome! Thanks man!!
ac, door, footwell
June 29 for Roush Creek try to plan bigkel162 Trips, Trails and Events 0 June 3rd, 2013 10:18 AM
Looks like my Jeep plan hit a snag.... an Airstream snag. Hans Misc. Chit-Chat 11 December 13th, 2010 07:01 PM
Drivers side bulkhead footwell repair panel for left hand drive D-90 Tyler Wirken Wanted 4 September 25th, 2008 12:26 AM
Bulkhead LH footwell repair panel? turbodave Defender Technical Discussions 1 August 22nd, 2008 03:03 PM
Help me plan my trip!! sflash868 Trips, Trails and Events 0 May 30th, 2006 09:15 PM
» Defender Registry
RAF
Realm
Maggie
rankar
Add your Defender
