FOG on windows - Defender Source
Old December 11th, 2003, 11:56 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
FOG on windows
I have a hard top and all my windows, inside, are so fogged up I can't see anything. There is so much moisture that I have water beads on the inside of my roof. Any suggestions?
Old December 11th, 2003, 01:08 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Richard,
That happened to a smaller extent in my 97 SW. Check for leaks in your seals/roof/windows. I did this at night with a Mag light. If you can see light then you can see water. I found a couple of leaks in my Door seals and on the roof.
I am going to wait until the winter is over and remove my entire head liner and take a look at it from the inside. I think it will solve any leaks I have as well as keeping the exterior looking good. I made some temp. sealing with a silicone marine sealer on the outside, but it took some time to do a clean job, which prompted me to think about doing from the inside.
Old December 11th, 2003, 01:23 PM
Where could i get a head liner for a NAS wagon?
Old December 11th, 2003, 02:46 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
The usual suspects. Roversnorth has some take-off and Rovers Down South. Worst case scenario you could try Badger Coach works.
Old December 12th, 2003, 09:19 AM
Mine does this sometimes when it rains, I have to let the defrosters run for a while without anyone inside to get all the moisture out of the air.
window, windows
Roll-up windows for a soft-top? jam90 Defender Technical Discussions 1 January 11th, 2006 11:33 AM
FS: D-90 Soft top less windows dzientek For Sale - Parts 10 September 19th, 2004 01:02 PM
ST windows slide Cyborg Defender Technical Discussions 3 May 10th, 2004 12:50 PM
More Softtop Help - 97' Windows jbird Defender Technical Discussions 2 April 27th, 2004 11:39 PM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 01:14 PM
