Fog lights - Defender Source
Old May 17th, 2004, 12:38 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Fog lights
I got a pair of hella 3000 (thanks to Mike) that I want to wire. I was wondering what is an easy power source under the hood I can tap into without any problems.
Rich
Old May 17th, 2004, 01:11 PM
Right off the alt. Then run your switch wire for the relay to the outside of the clutch filler there are 2 holes there that you can pass wires through. On the other side there is a cover on the dash that you can pull off (bottom right theres only 3 screws it also has the dash dimmer switch on it). Splice into the dimmer switch wire as your switch power (that way you can't leave the lights on by accident). And then you can mount the switch in that same panel.
I am going to do a right up on aux wiring one of theses days.
ht, lights
Fog Lights lynchee Defender Technical Discussions 1 October 29th, 2006 09:32 AM
fog lights in the bumper? pfmbf Misc. Chit-Chat 1 June 21st, 2006 09:18 AM
Hinged fog lights. rustydefender Defender Technical Discussions 2 February 28th, 2005 09:33 PM
Hella fog lights PT94D90 Defender Technical Discussions 1 February 4th, 2004 07:45 PM
Hella 4000 lights Nigel Buchan For Sale - Parts 4 November 26th, 2003 09:47 PM
