Fog light install - Defender Source
Old January 12th, 2004, 10:20 PM
SFD90
Payton Dobbs
95 Defender 90
Fog light install
I'm installing Hella fog lights on the front bumper and need some help. I haven't see how it's "supposed" to be done from the factory so I'm not sure what I'm aiming for.
Currently all I have are the two lights. There are two holes (too small) in the front bumper between the factory brush bar. I assume I should mount them there, but then they're not high enough to clear the cross-member on the brush bar. Is there supposed to be a mount or something?
Then I need to wire them. Where can I get the necessary harnesses, wires, switch, relays, etc.? And is there a LR switch that is supposed to be next to the dimmer? There is extra space there and I was wondering if that is where it should go.
Thanks in advance as always.
Old January 12th, 2004, 10:21 PM
you need this
Name:	light bar 2.jpg
another
Name:	light bar 1.jpg
Old January 12th, 2004, 10:23 PM
mounts in conjunction with the brush bar/bumper the lights sit on top.. It took me a while to find one. uh.. which hellas do you have?
this will hopefull help give and idea. you can see the mount and all
Old January 13th, 2004, 12:29 AM
Payton,
www.roversnorth.com sells the matching switch to the dimmer switch. Part # RNC938....$24.79. Good luck...Dave
Old January 13th, 2004, 01:42 PM
lobster's Avatar
lobster
Rob Goodall
1995 D90
You can buy that bar at a dealership. That is where I got mine then sold it to Philip, sucker! Just kidding Philip.
1995 D90 ST
1999 Super V8
Old January 13th, 2004, 01:45 PM
took me a while to find it tho
Old January 13th, 2004, 02:32 PM
SFD90
Payton Dobbs
95 Defender 90
Damn, thanks for the help guys. Of course it couldn't be easy. I'll look for that bar and hopefully get the switch for a clean install.
Old January 13th, 2004, 03:13 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Payton,
Which switch? There is an Auxiliary lighting swith that fits next to your dimmer and there is a wand switch that fits on the right hand side of the steering wheel.
EwS
Old January 13th, 2004, 05:17 PM
SFD90
Payton Dobbs
95 Defender 90
I'm assuming I want the aux. switch next to the dimmer. I think that'd look best and be as close to stock. Where can I find a wiring diagram or what relays to use?
BTW, I have the Hella FF1000s and I think they're considerably smaller than the ones posted earlier in this thread, the Rallye 3000s.
Old January 13th, 2004, 08:00 PM
the 4k's will not work in conjunction with the stocker bar. you would have to cut the grill.... i am gonna get a little bracket that will move the light out just enough to fit the depth of the 4k's. the switch that goes on the steering colum is kinda $$ from rovers north.......
Old January 13th, 2004, 09:27 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
The Steering column switch is nice though.
Phil,
Try the RN stainless grill. It's much nicer than the stock and it is much thinner. Might work w?o mods.
EwS
Old January 13th, 2004, 10:11 PM
I think i am gonna shell out for the colum switch. I have seen the RN grill its nice but to bling bling for me.
Old January 13th, 2004, 10:42 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Yeah, the silver one looks Bling. But the black looks real stealthy. Hard to tell it's even there.
Are you running a winch? I just looked at my SW and it looks real crowded up there. I hope that I can stuff the lights up there....
Old January 13th, 2004, 10:51 PM
me no winch.
ht
rear light electiral hook ups paulb Defender Technical Discussions 25 January 19th, 2010 03:25 PM
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
1 OE Land Rover LR3 Fog light rvrnut110 For Sale - Parts 0 October 17th, 2009 02:59 AM
License Plate LED Lamp & Rear Fog Lamp Install LenB Smaller Projects 24 December 16th, 2007 08:54 PM
Brake light on after brake install wicks Defender Technical Discussions 6 October 13th, 2003 07:01 PM
