FMS Replacement - Defender Source
Old June 8th, 2009, 02:18 AM
FMS Replacement
Any Ideas on Time it takes to do it? mine is leaking and its driving me nuts.
what else while your there
Assume - all belts
95' D90 - daily driver..
Old June 8th, 2009, 10:50 AM
FMS? Front main seal?
Check your hoses on the top of the motor for the PCV. When they clog it causes a front main seal leak when often there is nothing wrong with the seal.
If you have to change it is not too horrible. I did it on one of my discos way back when and other than getting the crank pully off, not biggy.
Ron
Old June 8th, 2009, 11:55 PM
Thanks Ron - does not sound horrible but i will prob ge the shop to do it at the next service.
Front main seal
PCV? any pictures of this? is it a breather hose?
Old June 9th, 2009, 12:24 AM
Positive Crankcase Ventilation. Looks for all the hoses going into the intake from the valve cover and the gray can on the front of the PS valve cover and clean them all out and replace as necessary. The gray can you take off and soak in fuel and clean out the wire wool or what not inside. Yes, breather hoses. I think there are two, but I would have to look to check (I know GEMS 1997s have two, but I have to go look on a 1993-95 to be sure as I don't have the image in my head beyond the grey can breather thing).
Old June 11th, 2009, 12:01 AM
i'll clean them this weekend and see if it stops - one question how does the grey canister come off? does it screw off?
ac
Tire replacement Dfndr90 Defender Technical Discussions 2 December 16th, 2005 02:06 PM
Clutch replacement difficulty? Trigger Defender Technical Discussions 3 July 25th, 2005 03:18 PM
rancho bushing replacement? jorge Defender Technical Discussions 6 April 7th, 2005 03:36 PM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
Replacement Headlamps tuko Defender Technical Discussions 4 November 18th, 2003 09:51 PM
