Flush of Fuel System (tdi) - Page 2 - Defender Source
Old July 1st, 2015, 10:55 AM
Howski's Avatar
Howski
Kevin
2002 Land Rover Discovery II
Cracked the drain plug and no water came out. The color was consistent with that of diesel. I replaced the line to bypass everything as was suggested and there was no difference so any line blockages seem to be out of the equation. The stumbling and cutting out seems to start once the turbo comes in. It's spitting out a light colored smoke and it begins stumbling. Later today I'll grab a fresh gallon of diesel and run it straight to the lift pump to see if its the fuel. With regards to timing, I replaced the timing belt about 18 months ~ 10k miles ago so I'm not sure anything would've caused it to stretch or get the timing out of whack this much. Very puzzled at this point
My other car's a Land Rover
Old July 1st, 2015, 11:23 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Just a quickie.. pull the bowl on the sedimenter - they fill with .. guess what .! mine was 3/4 full of gloop even though I had tapped it off every service to check for water.
there is a service kit available comprising of a couple of O rings and copper washers, if the bowl has not been removed recently get the kit before you start as the big O ring at the top of the bowl is normally perished.
as an aside if its stumbling when the turbo kicks in this is when it wants more fuel .. sounds like the engine side lift pump diaphram is holed.
Regards
Gren
Old July 1st, 2015, 12:10 PM
Howski's Avatar
Howski
Kevin
Tend to think that's not if as I had the same problems bypassing the sedimenter completely.
Checked the pickup in the tank and it was clear
Old July 1st, 2015, 12:12 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Kevin, glad to see your 90 home with you!
Old July 1st, 2015, 12:50 PM
cjbenway's Avatar
cjbenway
Chris Benway
1984 LR 90 ( Hedrick Rover )
Kevin, I had similar issues with my truck two years ago.
When the fuel filter was checked it was all clogged up with a rust color.
Turns out the fuel tank was rusting out. When I put in a new tank, fuel lines, and filter it ran like a champ. Thankfully the fuel injector system was good.
Hopefully this is not your problem.
Good luck!
Old July 1st, 2015, 05:49 PM
Howski's Avatar
Howski
Kevin
Originally Posted by cjbenway View Post
Kevin, I had similar issues with my truck two years ago. When the fuel filter was checked it was all clogged up with a rust color. Turns out the fuel tank was rusting out. When I put in a new tank, fuel lines, and filter it ran like a champ
Believe I can rule out most of those being the culprit as the issue persisted when both the filter and sedimenter were bypassed. I'm led to think it's either the fuel itself or something downstream of the sedimenter - possibly clogged lift pump, injection pump or injectors. I'm still new to diesels so I'm at a bit of a loss for common issues with the above noted pieces.
Old July 2nd, 2015, 05:51 PM
Howski's Avatar
Howski
Kevin
Ran a bit of clean diesel from a separate container through it and ran like a champ. I've got a feeling that the clowns at the storage place put petrol in the tank. Guess it'd be wise to purchase a 'diesel only' decal. Draining and refilling with additive tomorrow and she should be good to go
Old July 2nd, 2015, 06:44 PM
Naplm00
Matthew
Bingo, nice.
Rovahfarm has the aluminum "diesel only" decal plate for the filler
Old July 2nd, 2015, 08:43 PM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
1995 NAS Defender 90
Everyone should have one of these next to the filler.
Run a tank of biodiesel through it. Its more solvent and will help flush the system further.
Tiktaalik™
Old July 2nd, 2015, 11:54 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
As I explained to Kevin - diesel fuel gets a case of the "growies" (a biological form of algae that forms in the intercline between the fuel and the water that separates out when left sitting for an extended period). This green sludge can really gum up a diesel injection pump and injectors. A thorough flush and refill with a shot of Diesel-Kleen additive and new fuel filters will usually clear it up. Biodiesl will attack the fuel return tubing between the injectors unless you replace it with viton tubing (available from McMaster-Carr - I think it's 4mm but don't remember. Biodiesel does really clean out the fuel system though.
Old July 3rd, 2015, 12:15 AM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
Shouldn't the fuel filter take care of the algae? I assume you're running a filter. I upgraded to a 6" Stanadyne 2 micron filter.
It can take several years for the return lines to soften depending on what concentration and frequency which you run biodiesel so running a couple of tanks while your Viton hoses are on order should most likely not be a problem. The quality of the bio fuel may vary depending on your location so that's something to keep an eye on.
Tiktaalik™
Old July 3rd, 2015, 09:29 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
No algae in the fuel system will not be taken care of by the fuel filter.
There will be some that passes through and some always left in the infected tank, no matter how much polishing takes place.
Note that a micron rating of say 2, is NOT a filter that traps all particulate 2 micron and larger, it is a rating based on the smallest average size of particulate trapped during MULTIPLE PASSES through the filter.
Knowing a human hair is about 60 micron, switching from a 8 micron to a 2 micron will have a "splitting hairs" effect on fuel system filtering.
A sedimenter will do more to trap small particulate, long before it gets to the filter no matter what size micron rating it has.
RDavisinVA
Old July 5th, 2015, 02:46 PM
Howski's Avatar
Howski
Kevin
Got it drained, refilled, added Diesel Kleen and its running like a champ. Thanks for the input everyone
Sutars Recessed Flush Mount 12v sockets Uncle Douglas The Flea Market 14 August 23rd, 2012 09:25 PM
Cooling system flush rover4x4 Defender Technical Discussions 0 May 7th, 2010 05:40 PM
Need to change front timing cover seals, auto trans flush... NY/NJ/MA/VT/CT area? KKilo23 Defender Technical Discussions 4 September 21st, 2009 03:35 PM
Flush mounted rotating Pintle Hitch dmarchand Wanted 12 May 9th, 2008 12:51 PM
How do you flush a diesel tank EdHsu Defender Technical Discussions 8 November 19th, 2004 05:48 PM
