Fluids - Defender Source
Old October 16th, 2010, 08:22 PM
Palomino
Rico Palomino
1995 D90 SW #001
Fluids
OK. I know what the owners manual says to run for the diff's, tranny, and transfer case. but what do you run? Just wondering if anyone runs different fluids. The first time I changed my tranny fluid I was surprised that it took "type F " fluid instead of gear oil like my SIIa.
I also was told not to run synthetic gear oil in my front diff with an ARB air locker but that it was OK in the rear diff with the true trac. I just run regular gear oil in both to make it simple.
Any opinions?
Rico
Old October 16th, 2010, 09:02 PM
Redline MTL in the transmission use the cheapest shit you can find for the rest of the driveline
Old October 16th, 2010, 09:33 PM
I run synthetic in everything, including my diffs and I have ARB's front and rear. I also run Molly Grease in the swivel balls.
Old October 16th, 2010, 10:22 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Any opinions?
Rico
specifically regarding the transmission -
I have 3 quarts of Amsoil Manual Syncromesh trans fluid that somebody gave me a few years ago I'm going to try in the R380 tomorrow, i'll post back my thoughts. I've also had good luck (with my TJ's NV3550) with Pennzoil's Syncromesh fluid too. They seem comparable to the MTL/Texaco MT85 or whatever the number was.
This one? http://www.schaefferoil.com/238_moly_grease.html
What about a good marine-grade grease (bearing grease) in the swivels? I'm currently running oil and its not leaking, I'm just curious what people thought.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old October 17th, 2010, 02:43 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
just put 3 quarts of this http://www.amsoil.com/storefront/mtf.aspx in (jacked up the RHD drivers side).
Shifting seems smoother, not sure if its placebo or not but I'm satisfied.
~2008 GTI TSI
Fluids tomaco1 Defender Technical Discussions 1 December 16th, 2007 07:43 PM
Man trans & t-case fluids dnp Defender Technical Discussions 24 June 13th, 2007 01:45 PM
R380 LT230 Fluids ronward Defender Technical Discussions 13 September 21st, 2006 11:28 PM
Changing fluids? Defender13 Defender Technical Discussions 1 July 24th, 2006 10:23 PM
fluid change on a ZF4HP22 D90_Camel Defender Technical Discussions 3 June 2nd, 2005 04:41 AM
