Fluid/Oil Leak - 85 D90 - Defender Source
Old May 8th, 2015, 11:02 PM
Solihull
Copley's Dad
85 D90 S Top + 06 Supercharged RR
Wink Fluid/Oil Leak - 85 D90
I noticed on my garage floor that their was some fluid/oil leaking. Vehicle in question is a 2866 CC Petrol 1985 D90 with a manual gearbox. Attaching a picture where it is leaking. Is this an easy fix? Is there a forum sponsor or recommended vendor that will have the necessary parts for the fix?
Current Vehicles:
1985 Defender 90 Soft Top
1992 Range Rover Classic
1998 Porsche Boxster
2000 Supercharged Jaguar XJR X308
2006 Supercharged Range Rover
Looking to add:
Ferrari 328 GTS
Classic Rolls Royce
90, d90
Brake fluid leak? Surf90 Defender Technical Discussions 4 March 21st, 2013 04:34 PM
Oil Leak..Oil Pressure Switch Failure? tebby Defender Technical Discussions 2 December 19th, 2010 03:16 PM
Brake Fluid Resevoir leak Lriwater Defender Technical Discussions 13 December 3rd, 2010 08:37 PM
Dot4/Brake/Clutch/PS/etc fluid leak from front driverside? nathanwind Defender Technical Discussions 9 May 14th, 2010 01:46 PM
