Fluid Help - Defender Source
Old April 29th, 2012, 08:32 PM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
Fluid Help
Anyone ever wrote up a spreadsheet for the different fluids recommended our trucks? I need some help/ recommendations for mine.
1992 D90
motor: 200 tdi (oil type)
tranny lt77 (gear oil type)
Radaitor (color or type)
power steering (type)
Power brakes (type)
everything else that leaks!!! (type)
Thanks for the help!
Old April 29th, 2012, 09:03 PM
What did you search for to try to find a thread? If you had searched "fluid tranny" or anything this should have come up.
http://www.defendersource.com/forum/...ad.php?t=35544
Old April 29th, 2012, 09:12 PM
Rosproline157
Matt Oaks
1992 Defender 90
I searched random threads looking for all the answers. My truck is road ready finally and I need to top everything off..
Old April 29th, 2012, 10:41 PM
I dunno about your truck, but the owners manual for the Range Rover has all the specs for lube and fluids.
I shop for goo at the Tractor Supply, Atlantic Tractor, Wal mart and sometimes Costco.
I generally use Rotella in the engine and el cheapo for 90 wt and dexron 3. I do have a 5 gallon bucket of John Deere gear oil that was a good deal. Coolant is Dex cool. Brake fluid always Girling.
Get a bottle pump for your gear oil and change the diffs at least once a year.
Old April 29th, 2012, 11:25 PM
texrover's Avatar
texrover
Jason
http://defender-manuals.s3.amazonaws..._WSM_book1.pdf
See chapter 9
Old April 29th, 2012, 11:30 PM
motor: 200 tdi (oil type) Rotella 15W40
tranny lt77 (gear oil type) Redline MTL
Radaitor (color or type) cheap green stuff cut with distilled water
power steering (type) ATF Dexron IV
Power brakes (type) Castrol GT LMA
Don't forget the transfer case (80-90W...something like Lucas or Mobil 1), diffs (same 80-90W), and swivel balls (any 80-90W).
Old April 30th, 2012, 12:49 AM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Clutch Cartrol GT LMA too
Gear fluid ..... Rover- Girl Defender Technical Discussions 3 October 9th, 2005 05:25 PM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
ZF fluid level goes up and down 48vphantom Defender Technical Discussions 4 March 20th, 2005 01:42 PM
» Defender Registry
Big Bird
owen
NAS 110
Pugsly
Add your Defender
