fluid change - Defender Source
Old April 1st, 2011, 08:32 AM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
fluid change
I am changing all my fluids this weekend, and wanted some input on a few things:
1. Opinions on diff oil for ARB's
2. Oil for a 94 D90 with 113000 miles on it
3. Part number for oil filter (wix)
4. Transfer case oil
What do you guys use? I've been using high mileage oil, and 80w90 in my diffs, but just installed ARB's and want to see what you are using in your trucks.
That is why it is called a short cut. If it was easy it would just be "the way."
Old April 1st, 2011, 09:30 AM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
I've got 122,000 miles on my rig, and have been using Mobil 1 10w40 high mileage synthetic oil but plan on switching over to Rotella next change. I use the Redline MTL for tbox as well.
Old April 1st, 2011, 09:39 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Originally Posted by TexasD-90 View Post
2. Oil for a 94 D90 with 113000 miles on it.
0w40 Mobile 1 for synthetic
15w40 Rotella T for Dino
Old April 1st, 2011, 09:56 AM
dchapman
Daniel Chapman
1999 D1
1) Use what ever is cheap and change it often. The slightest amount of water contamination will ruin your ARB o-rings. I change my diff fluid with every oil change at ~3,000 miles.
2) After tearing into a few Rover engines, I now swear by Rotella-T oil.
3) WIX and Mann are the same filter with two different names printed on them. The Mann is a little cheaper in price.
WIX: 51515
Mann: ERR3340M
4) I like the Castrol EPX 90. It meets the MIL spec's (MIL-L-2105 or MIL-L-2108 B, C, and D) and seems to have worked well over the years.
Old April 1st, 2011, 10:04 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Continuing 80w90 will be fine for the ARBs, they're not picky. I'm not convinced the synthetics are worth it. Rover V8's do well on Rotella, x2 on that recommendation. The LT230 also wants 80w90. Redline MTL is a bit light unless you live in a cold place year round.
Tony
1984 110 "Smokey" (sold)
Old April 1st, 2011, 07:01 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I know you didn't specifically ask for transmission fluid, but I used Amsoil Syncromesh Manual Transmission Fluid (also says 5W-30 on the bottle) in my R380 replacing whatever was in there before. I've noticed a difference (for the good) in shifting, especially in cold temps and between 1st and 2nd
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old April 1st, 2011, 07:41 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Redline MTL for an R380, but the LT230 needs 90w, or 85w140, depending on environment.
I started using Drydene ESGL 85w140 years ago and continued after they got bought out by Castrol. I've used it from Georgia to Vermont year round.
WIX 51515 is the long filter. Baldwin/Hastings B2 is another quality long filter.
I pay about $5 for the 51515 here at a local heavy truck supply place.
Unless things have changed recently, MANN filters are made by the MANN-HUMMEL group. I don't see any connection between the two.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 2nd, 2011, 09:07 AM
NAPA1452 filter. The specs on that Mobil 10w40 high mileage are pretty awesome, Ive been using the Amsoil 10w40 with zinc, amsoil specs are awesome but its a pita ass to get sometimes. I know at my local vatozone the Mobil is priced closer to Amsoil lately.
Old April 2nd, 2011, 02:39 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Royal Purple in everything. Synchromax in the tranny and 75w90 max-gear in the diffs and t-box. There is a noticeable difference.
Old April 2nd, 2011, 03:01 PM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
Talking
FYI: The wix filter (I get it from Checker/O'Reilly's) is about $5 whereas the Napa branded wix here costs $12 for what appears to be the same filter.
Thanks to Tom I've been saving $7 an oil change.
Old April 2nd, 2011, 04:13 PM
Nothing beats Redline MTL in an R380, Ive tried them ALL. I always get my filters from NAPA, if they were good enough for the drill they are good for the rover.
Old April 10th, 2011, 05:46 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
Is the 51515 filter too long for a 94 3.9?
Swivel Ball Fluid Change Help Please isleofbones Defender Technical Discussions 2 September 5th, 2009 12:58 PM
fluid change question JBOD77 Defender Technical Discussions 15 March 29th, 2009 11:22 PM
fluid change on a ZF4HP22 D90_Camel Defender Technical Discussions 3 June 2nd, 2005 04:41 AM
ZF fluid level goes up and down 48vphantom Defender Technical Discussions 4 March 20th, 2005 01:42 PM
