fluctuating idle - Defender Source
Old November 28th, 2003, 11:54 AM
KeithElisa's Avatar
KeithElisa
Keith Parkin
Angry fluctuating idle
I have some strange idle problems with 97 D90. My idle keeps dropping so low the engine cuts off. It comes and goes off and on. I have changed the fuel filter and the air filter and pulled out the air idle valve and cleaned it. Anyone had this problem or have any advice?
Keith
Old November 28th, 2003, 04:43 PM
If you have not checked it out yet look here. I had a similar problem, the plugs on the distributor cap were corroded. I also ran some injector cleaner threw the system and the problem went away.
Old November 28th, 2003, 05:42 PM
Replace the Crankcase breather hoses. They are plugged and contributing to the fault. Next check the vacuum lines. Also make sure you are not low on oil.
If this does not help you have an issue with a sensor out of spec so you will need to trouble shoot further.
Ron
Old November 29th, 2003, 09:20 AM
Keith, I like the Avatar! who is the young driver.
Old November 29th, 2003, 09:22 AM
doh! double post!
Old November 29th, 2003, 04:03 PM
scot's Avatar
scot
Scot Yount
95 Coniston Green D-90 SW
Another possibility is the stepper motor....it is part of the gizmo that sets the idle, and I have had one go bad before. I don't know if that is the same part you describe as the air idle valve, but it could be. My first truck behaved exactly as you describe your problem. They (stepper motors) can be removed cleaned and lubed if they are failing and sometimes they will work well for another year or so. But as I said...I ended up having to replace one...which sucked. I can't remember how much I paid but it was a few hundred dollars.
Wherever I go...there I am.
Old November 30th, 2003, 07:09 AM
KeithElisa's Avatar
KeithElisa
Keith Parkin
Mike, That would be my son and future land rover driver, Colin. He's just turned one. My 3 year old daughter Leah loves rovers also.
Old December 1st, 2003, 05:17 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Air flow meter is probably at fault
Mike Hammond
Old December 2nd, 2003, 02:43 PM
KeithElisa's Avatar
KeithElisa
Keith Parkin
Where would that be located?
Old December 5th, 2003, 01:08 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
I assume from your profile this is a 97. GEMS. Is the check engine light on? Has the battery gone dead or been disconnected recently? If so, the adaptive variables may need to be reset. (Requires a Rovacom/Testbook/T4) The TPS could be out of adjustment or faulty. If the TPS is not below 13%, the GEMS won't control the idle. This can be tested with a volt meter.
A generic OBDII scanner can verify these.
Nick
Old December 5th, 2003, 07:05 AM
KeithElisa's Avatar
KeithElisa
Keith Parkin
Yes, it's a 97 and the check engine light never came on. But I do have a battery disconnect on my ground terminal that I keep disconnected for up to a week at a time. The reason for the disconnect is I have a mystery battery drain that I could never find.
I don't have a test book or a scanner. I hate to go back to the dealer they never seem to find or fix anything but I think this problem might be out of my league. I do have a volt meter and a shop manual.
Old December 5th, 2003, 12:40 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Post on the www.LRX.com forum, and Mike Green will give u some ideas I'm sure -- he is a genius IMHO.
DW
Old May 29th, 2006, 02:46 PM
kkaiserblu
robert didona
hello
I was wondering if you could show me or tell me where the steppor motor is exactly?
Old May 29th, 2006, 04:08 PM
redrover
Guest
Posts: n/a
X marks the spot. JP
Old May 29th, 2006, 10:07 PM
Hoss
Jeff Sturgis
1995/D-90
My money is on the stepper motor. When it is faulty you will get a fluctuation that sounds like your issue. The part is not cheap, but it is an easy replacement.
Good luck with the fix.
Old May 31st, 2006, 08:38 AM
Heath's Avatar
Heath
Heath Ahrens
1995/D-90
I have had problems that were related to the speed transducer. The transducer did not throw a code for a long time... it threw a lambda sensor code (44 or 45 i think). I did switch the idle stepper motor, several hoses, and tested throttle position sensor, set base idle, rotor cap, distributor coil (with mallory unilite), and the o2 sensors.
All of these things can cause idle problems. Could it be related to speed. When you slow down? Randomly? And as for the stepper motor, you can get one from NAPA.
idle
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
High Idle tron Defender Technical Discussions 5 February 15th, 2006 03:33 PM
The latest show-stopper: dies at idle, only runs above 2K rpm jaherring Defender Technical Discussions 34 December 23rd, 2004 07:05 PM
Weird sound at idle... OCD90 Defender Technical Discussions 1 November 10th, 2003 02:56 PM
