floor pan screws - Defender Source
Old August 28th, 2011, 05:27 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
floor pan screws
I started to try and take apart the floors in my truck and got shot down on the first screw. What are the nubs those screws go into, are they plastic? I can square off the heads so I can get a wrench on them but I am afraid I will just bust them. Is it feasible to grind them off, beat them through and just use new bolts with a nut on the bottom? The thought of more nut-bolt combos makes me cringe but if I have to I will. I want to do this so I can replace all the fasteners with SS so I can bury it all with Dynamat and not have to worry about it down the road
Thanks for any suggestions!
Old August 28th, 2011, 05:33 PM
grnrvrs's Avatar
grnrvrs
Paul
88
An angle grinder will make short work of rusted fasteners. Replace with new and use plenty of anti-sieze lube.
Old August 28th, 2011, 06:01 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
What are the little blocks the screws go into, are they plastic? I really don't want to replace anything I don't have to
Old August 28th, 2011, 06:07 PM
gchinsr's Avatar
gchinsr
Greg Chin Sr
1996 Discovery 5 Speed
Those are Mudflap Lokut Nuts. Odd name. Nylon inserts. I used the Dremel tool to cut channel for a larger standard screw driver, then it was no problem to remove.
Old August 28th, 2011, 06:14 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Cool, thanks. There are quite a few missing with a bunch of different fasteners holding the floors in. Are the lock nuts attached some how or is it just the undercoating spray holding them on the underside of the truck?
Old August 28th, 2011, 06:18 PM
gchinsr's Avatar
gchinsr
Greg Chin Sr
They are sandwiched to the floor board, at least on Lizzy.
Old August 28th, 2011, 06:30 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
You know of a source for them?
Never mind, found them at Rimmer Bros.
Old August 28th, 2011, 06:32 PM
gchinsr's Avatar
gchinsr
Greg Chin Sr
Rimmer Bros. I buy most everything I need from them, great customer service. Choose UPS, and for a few bucks more get it in 2-3 days if in a rush.
------ Follow up post added August 28th, 2011 03:35 PM ------
Here is the link http://www.rimmerbros.co.uk/Item--i-GRID010586
Steering column cowl screws rover4x4 Defender Technical Discussions 1 December 11th, 2010 12:12 PM
Stainless hinge/hood screws & ARB Skid Plate GMFett Defender Technical Discussions 7 October 21st, 2009 12:28 AM
stripped lens screws? Caribsurf Defender Technical Discussions 4 July 10th, 2007 05:42 PM
Safari Guard grill screws needed Caribsurf Defender Technical Discussions 7 February 26th, 2007 03:57 PM
Rear Door Hinge Screws Rob Defender Technical Discussions 1 October 12th, 2003 06:46 AM
