Floor area getting hot while driving...solution? - Defender Source
Old July 11th, 2014, 11:06 AM
KKilo23's Avatar
KKilo23
Kenny
I understand this is a common issue in these trucks with the matting removed. I have Line-X'd floors and the OE rubber matting system is no longer installed.
What solutions are there to cut down on the heat from tunnel/bulkhead etc?
Old July 11th, 2014, 11:14 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Take the top and window tops off?
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
ha!!
Old July 11th, 2014, 11:18 AM
airbornrover
William Skidmore
SIII 109 SW
And wear flip flops. In the winter time you dont have to worry about it.
Old July 11th, 2014, 11:20 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Or drive it through a couple of Vermont winters, you'll get plenty of speed holes in the bulkhead to keep the feet cool.
Old July 11th, 2014, 11:22 AM
Guess why I went out for my drive first thing this morning.......So much nicer than later in the day.
I'm thinking of dynamating the tunnel (its all bare right now) as a heat insulator. Over that I'm thinking about the bedrug solution that Kolton went with.
http://www.defendersource.com/forum/...ghlight=bedrug
Old July 11th, 2014, 04:01 PM
KKilo23's Avatar
KKilo23
Kenny
Obviously have never driven an NAS ST then.
I run no top or windows. Flip flops make it worse.
------ Follow up post added July 11th, 2014 01:03 PM ------
No thanks. I have already rebuilt one rust bucket...haha
Old July 11th, 2014, 04:32 PM
Wait you removed all of the rubber from the floor and you're wondering why it's getting hot? It's all about insulation and creating a heat barrier, or at least reflecting the heat.
Old July 11th, 2014, 04:36 PM
KKilo23's Avatar
KKilo23
Kenny
I know crazy right.
Previous owner kindly did.
Knowing what to buy and install would help...not trying to reinvent the wheel here.
Old July 11th, 2014, 04:40 PM
In the for sale parts section I could have sworn someone was just selling the proper/original rubber and foam insulated R380 tunnel cover. You can also go all out and do a combo of the Exmoor system and probably use some of the dynamat stuff (or something better at reflecting heat) to try to reflect some of the heat to keep it from transferring to the cabin in the first place.
Old July 11th, 2014, 04:46 PM
KKilo23's Avatar
KKilo23
Kenny
I was thinking the Exmoor System as well with the dynamat or putting all original flooring in if I can source.
How is yours with Rhino and OE rubber?
Old July 11th, 2014, 04:49 PM
Well, the rubber tunnel cover on mine is bubbled (I'm assuming from the heat) I'm not sure when it happened, but it was before I bought it. I'd love to do the whole Emoore system to make the interior look more finished, and help dissipate any additional heat coming from the engine/trans.
Old July 11th, 2014, 06:32 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
I just have the rubber Defender mats front and rear. They get a little warm, nothing crazy. I don't think many people get a Defender for their luxury and comfort.
Old July 11th, 2014, 06:38 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Dumping excess gas making those cats extra toasty? What is your MPG?
Old July 11th, 2014, 08:37 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Try this company: www.lobucrod.com
No affiliation, but I just bought a roll for my 110 after coming across a posting on the product and reading the website. Can't say that I've tried it yet, because I'm still repairing some rust areas in my rig, but I bought enough to use on all of the horizontal surfaces including the transmission tunnel and the cargo area.
I plan to install automotive carpeting on top of it to lower noise and increase "comfort".
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old July 11th, 2014, 09:10 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I think i'm gonna look into that universal Bedrug idea. Looks like it has the thickness to help insulate and the durability to be used on the floor. Thanks for the link!
Old July 11th, 2014, 10:21 PM
Kenny- you need to do the underside of the floors with something with a mylar or similar facing to reflect the heat. Doing it inside now will have minimal effect. Dark colored bedliner acts as a heats sink and makes it worse. FWIW the Exmoor/Wright Offroad stuff doesn't dissipate the heat as Josh eludes to. On the contrary, it's insulation to block it.
Old July 11th, 2014, 11:01 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I agree with Uncle Doug. I'd start with a heat shield between the cat's and the floor board underneath the vehicle. Bend up some thin sheet metal, and tack/screw it to the framing.
Old July 11th, 2014, 11:20 PM
Jedelmann's Avatar
Jedelmann
John Edelmann
1994 Defender #1194
Heat reduction
I added two layers of Dynamat Extreme to the tunnel, bulkhead, floor, seat boxes and doors - plus added the Exmoor matting plus LR signature floor mats. It dramatically reduced both the heat and road noise.
84 110 Dormobile
94 D90 ST
14 RRS
Old July 11th, 2014, 11:51 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I've used this stuff on the inside of the tunnel and under the floor boards.
http://www.designengineering.com/cat...und-insulation
It's has a super strong self adhesive, a layer of insulation and a layer of aluminum.
Headlights lost while driving the_eaze Defender Technical Discussions 11 November 1st, 2011 11:58 PM
Tire change while driving video..whoa BOBCAT110 Misc. Chit-Chat 7 August 22nd, 2011 01:38 PM
A/C Help......hot, hot, hot! boulderbear Defender Technical Discussions 7 August 26th, 2006 07:54 PM
The shakes..while driving.. arbik Defender Technical Discussions 4 December 7th, 2005 12:08 PM
Strange feeling while driving... wicks Misc. Chit-Chat 5 March 3rd, 2005 01:37 PM
