flooded engine? - Defender Source
Old January 21st, 2008, 07:06 PM
flooded engine?
Left for work this am and it was cold maybe upper teens low 20's. I started up the truck and let it idle for a minute started out and stalled. When I tried to restart it wouldnt start. It took a couple tries but eventually got going again, I had to give it gas and what not. Question is this, did I actually flood the truck out? I didnt think it was possible to flood EFI, also would it be worth while to check to see if a plug got fouled? It ran fine on the way to work. I wonder if I did any damage to the starter? thanks
Old January 22nd, 2008, 12:44 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Could be tons of different things, but one that jumped straight to my mind was that your idle air control plunger got stuck.
Old January 22nd, 2008, 05:45 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Yes, it is. EFI does not (and can not) check if there was a spark or enough air in each cylinder, so fuel will still get into each cylinder.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old January 22nd, 2008, 06:25 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
If it happens again, and you suspect the engine is flooded, try unplugging the coil. This will help clear the cylinders. It will start then sputter out. Reconnect, and the engine should start, assuming there are no other issues.
"Uhh...I think they all leak like that."
Old January 23rd, 2008, 12:20 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
I would suspect just the opposite. It isn't going to start without the coil connected and it floods because there is no spark in the first place.
Did you mean unplugging the injectors or computer?
Old January 23rd, 2008, 01:10 AM
pendy's Avatar
pendy
jim pendleton
89'd90
He means to unplug the fuel injection signal connection from the coil. It will stop firing the injectors to help clear out the fuel.
legend in my own mind
Old January 23rd, 2008, 12:25 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
Yes, that's what I meant. It's a little plug on the bottom, IIRC. Maybe I just need to stop dispensing advice.
Old January 23rd, 2008, 01:00 PM
cellulararrest
Chris Snyder
Nah sorry. I just read coil and was confused. Sorry.
Old January 24th, 2008, 02:01 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
This may not be the case but when I had a 3.9 I had very similar symptoms before my cpu went south.
It was flooding horribly, thought it was the optical thingy in the mallory distributer, which was fried, but when I put a new one in it fried too. turned out to be the cpu...I'm not saying this is your problem just an FYI.
engine
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
Yet another engine fire chrisvonc Misc. Chit-Chat 80 August 30th, 2005 02:22 PM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
