Flickering LCD in my Speedometer - Defender Source
Old December 16th, 2011, 02:01 PM
hunterjah's Avatar
hunterjah
Jesse Hardin
Past: '97 D90 LE #135
All,
I've searched enough to know the 97's had issues with the speedometers going bad. Here's my issue: in the LCD displaying mileage (aka odometer), I've recently noticed the LCD is becoming faint and will occasionally flicker. It hasn't gotten to a point where the LCD completely goes blank, but I'm worried the unit may be going bad. Any recommendations on what to check?
Also, I've had several check engine lights related to the "Vehicle Speed Sensor". Could these two issues be tied together? I also was curious if this could be related to a few recent rains we've had. Could moisture play any role?
Current Stable:
2016 BMW M3 (Mineral Grey)
2013 Ford Raptor (Tuxedo Black)
Previous Rovers:
1997 LR D90 LE - #135
1997 LR D90 ST - #1185 (BRG)
2000 LR Discovery SII (Oxford Blue)
2008 LR LR3 HSE (Alaska White)
2012 LR LR4 Lux (Fuji White)
Old December 16th, 2011, 02:36 PM
BOBCAT110's Avatar
BOBCAT110
Ken Jagolta
94 d-90
Any respectable speedo shop can replace the lcd screen. The original miles will be retained. It is quick and easy . Also cheaper than buying a new speedo.
Weather does seem to play a part. They seem to flicker and go blank during rainy days on units that are starting to fail. I doubt your codes have anything to do with the speedo display.
I can refer you to a good speedo shop if you do not have one locally.
Old December 16th, 2011, 03:29 PM
I've had a flicker for a few years. comes and goes. annoying. going to replace with vdo adjustable at some point, unless I could find a speedo shop somewhere here. being in nascar alley, I may get lucky.
Old December 16th, 2011, 03:45 PM
Which speedo do you have? Yours should be analog.
Old December 16th, 2011, 06:03 PM
Pendy put a 97 in during my rebuild, along with the sensor.
Old December 17th, 2011, 08:53 PM
Tkleis
Tim Kleiser
97 Defender 90
I have the same problem with my 97 D-90 speedo. Anyone have a good speedo repair shop I could send it to for repair?
Old December 17th, 2011, 09:52 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
I think Hollywood speedo does it. ECR did once, but not anymore
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old December 17th, 2011, 10:27 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
Yeah North Hollywood Speedometer can fix the odometer LCD issue, they did mine and were able to retain the original mileage and now it works petfectly. Did you get the code(s) associated with check engine light?
Old December 17th, 2011, 10:40 PM
hunterjah's Avatar
hunterjah
Jesse Hardin
I did, don't remember the exact code, but it's the Vehicle Speed Sensor. I've gotten the same code several times on my handheld reader. I'm not getting any other codes. I guess my conundrum is do I replace the speed sensor to try and trouble shoot that to start with, or do I try and trouble shoot the speedo. I think they're unrelated, so I may just go ahead and replace the speed sensor since there's clearly something going on there. Then, if the LCD is still acting up, I'll send it out.
Current Stable:
Previous Rovers:
Old December 18th, 2011, 07:04 AM
Reese_D90's Avatar
Reese_D90
Reese
Not related issues. Depending on the cost to fix the original speedo, you can also buy a new LR one and hollywood speedo will advance the miles to match. Just another option if the first is too much.
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old December 18th, 2011, 12:52 PM
BOBCAT110's Avatar
BOBCAT110
Ken Jagolta
94 d-90
The local shop we use charges between $185 - $295, depending on what it needs. They also usually call that it is finished before I even can get back home. PM me if anyone wants their number. I have no affiliation with them.
Old December 23rd, 2011, 11:11 PM
aaronlam's Avatar
aaronlam
aaron lam
1997 Alpine White D90 SW #2212
FWIW, I took my Speedo out to get the ODO fixed and it threw the Vehicle Speed Sensor code. Sent the Speedo to North Hollywood Speedo and with a bit of begging, they were gracious enough to turn it around in 3 hours (I have to take it to the DMV next week). Their service is amazing... cost was $250 + tax. Code went away after I returned the Speedo.
Old December 24th, 2011, 10:02 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
That's normal. On the 97s the vehicle speed sensor goes through the speedo and then on to the ECU. So if you unplug the speedo the ECU never gets the speed sense signal.
cd, speedo
Detach Speedometer Cable Matt Klapmust Defender Technical Discussions 2 October 2nd, 2013 01:43 PM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 10:20 PM
Milage/ Speedometer calibration? oldscratchggf Defender Technical Discussions 3 January 3rd, 2006 03:59 PM
Correcting speedometer after lift/tires Seriesman Defender Technical Discussions 16 November 24th, 2005 08:37 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
» Defender Registry
Mancar
emah
"HAL"
redrange
Add your Defender
