flexible stereo antenna recommendations - Defender Source
Old January 30th, 2012, 02:04 PM
wilyliang's Avatar
wilyliang
Peter
'95 D90 SW #441
Anyone have a recommendation for a short (rubber) flexible am/fm antenna to replace the stock one on a '95 d90 DW? Radio shack has one and even Kragen/O'Reilly's, but they are pretty cheap.
Old January 30th, 2012, 02:20 PM
They suck. Tried it and threw it up. You will not get the same reception. Get a straight steel whip from autozone, etc (not the protracted type) and it'll be flexible enough and yet give you better reception.
BTW, if you have a metal raised air intake and the antennae is close to that, relocate the antennae. trust me.
Old January 30th, 2012, 04:17 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
What's the reason for the whip? As Overlander said, the reception is pretty poor. I installed a power unit in mine and while it was a little more money, I really like that when the radio (or truck) is off, the antenna retracts down. I especially like it for when I am wheeling as I can still listen to a CD or iPod but the antenna remains down
Old January 30th, 2012, 04:38 PM
SBrick
Scott Brick
1995/d90
antenna
a little off subject. Is the defender 90 stock radio antenna power retractable? I just put a new stereo in and the antenna does not move after replacing stock tape deck. IE do you have to manually put the antenna up and down or do I have a bad connection or motor?
Old January 30th, 2012, 04:43 PM
bad motor more than likely - especially in the Winter
Old January 30th, 2012, 04:50 PM
SBrick
Scott Brick
1995/d90
any idea where I can get one of those motors ?
Old January 30th, 2012, 04:58 PM
Atlantic British would be a good place to start.
Old January 30th, 2012, 05:45 PM
Skeena river rover's Avatar
Skeena river rover
jeroen
1997 300 TDI 110
I removed my antenna from the wing, and took a inside one. You can stick it on the windshield underneath the rear view mirror. You can see it on the picture. Works great and out of the way!
Old January 30th, 2012, 06:36 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Just remove the radio. Cures all problems...
Old January 30th, 2012, 06:41 PM
specops1526's Avatar
specops1526
Beluga '97 90
The flexible ones start to look ghetto after a while. They start to bend after a period of time. I'd say stick with the stock manual retractable one. Pull it up when you need it and push it down when you need it out of the way.
And, no, the stock antenna is not power retractable
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old January 30th, 2012, 07:26 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
can that be my signature line?
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old January 30th, 2012, 07:38 PM
wilyliang's Avatar
wilyliang
Peter
'95 D90 SW #441
Just wanted something a little more durable and less tempting to wire-scupltor hoodlums. Was the power unit hard to install?
Old January 30th, 2012, 07:44 PM
specops1526
Beluga '97 90
You got it!
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old January 31st, 2012, 09:13 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
No, the power unit was very simple. I found a Metra power antenna on Amazon with specs (mounting hole diameter and antenna mast length) similar to the stock manual antenna and then fished the unit under the fender (this is the hardest part as it is a little tight with the brake and clutch MC right there. Hook up a power, ground and the lead from the stereo along with the antenna signal cable and voila! I would say that the process takes about 15 minutes longer than installing a non-power unit.
Old March 16th, 2013, 07:03 AM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Bringing this up. How hard is it to replace the antenna, as I will be replacing them? Can you guide me to the steps. Thank you.
Old March 19th, 2013, 10:31 PM
redway77's Avatar
redway77
Beatrix
110
Mine is stuck too I'm would like to replace it aswell.
flex, stereo
OEM Antenna or Replacements boshea Defender Technical Discussions 14 January 18th, 2006 01:15 PM
Stereo question oldscratchggf Defender Technical Discussions 4 December 19th, 2005 08:49 PM
CB Antenna Splitter bjenk Defender Technical Discussions 2 March 28th, 2005 08:45 AM
Antenna Wanted For 95 D90 Rockhead12 Wanted 2 January 12th, 2005 06:12 PM
D110 Stereo wiring pcarey Defender Technical Discussions 1 November 23rd, 2003 10:57 PM
