flexible intercooler hose - Defender Source
Old May 6th, 2013, 03:43 PM
Sandt's Avatar
Sandt
Sandt Michener
1984 Ninety
Anyone use some sort of flexible hose for their intercooler piping?
I have quite circuitous routes and am wondering if there is such a solution out there...
Old May 6th, 2013, 03:52 PM
Shieldsflex II marine exhaust hose. Comes in 2 1/4 ID.
http://www.jamestowndistributors.com...d+Exhaust+Hose
You could also have a muffler shop make your custom bends from stainless and then you just need the silicone connectors
Old May 6th, 2013, 03:55 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
I bent a pc of welding wire and took it I an exhaust shop. They bent me a hard exhaust line for $20. I had them cut it long so I could cut to length at the house. Worked really well, with the exhaust port it needs to be able to handle some heat, other wise it will just melt.
------ Follow up post added May 6th, 2013 03:56 PM ------
That's works as well!
ESR2309 replacement? 300Tdi intercooler top hose artm Defender Technical Discussions 3 August 14th, 2010 10:02 AM
Tdi Intercooler Hose Diameter? Wolf Fabrication Defender Technical Discussions 5 March 13th, 2010 06:12 AM
300Tdi Intercooler Hose Bracket... TDI Guy Defender Technical Discussions 8 April 24th, 2009 10:46 AM
Stupid vacuum hose Mike Hippert Defender Technical Discussions 7 November 9th, 2005 09:00 PM
air intake hose?? / source for cheap switches NASD90 Defender Technical Discussions 15 July 6th, 2005 02:40 PM
