Flex Fan for a 90 - Defender Source
Old September 13th, 2004, 08:36 PM
BrknRvr
Ben Kemple
Locked '94 D-90 33"MTR
Flex Fan for a 90
Does anyone make a flex fan for the 3.9? I hear they are cheaper and dont need a fan clutch.
BrknRvr
Old September 14th, 2004, 02:39 AM
Hollywood
alex howell
94 d90
the flexi-a-lite 210 is available through summit racing, also available is an override switch. i got it installed and it rocks. my radiator guy said it seemed like it was made for the d90.
Old September 14th, 2004, 01:30 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I installed dual 12" Hayden electric fans. It only took an afternoon and it works great! No more clutch fan (which had a worn-out clutch for me), no chance of overheating due to low RPMs in stop-and-go hot weather traffic, and some measure of redundancy with two fans. This probably saves more HP by having less of a load on the engine.
I could have gone with one larger fan (14" is the biggest that will fit height-wise) but the dual 12" fans look like they were made for this radiator. I'm super-happy with the result.
Old September 14th, 2004, 01:53 PM
scrover
Steve Cooper
93 RRC LWB
Originally Posted by BrknRvr
Does anyone make a flex fan for the 3.9? I hear they are cheaper and don't need a fan clutch.
BrknRvr
I got a metal fan from Autozone for $24.95 (I think that's what you where asking about right?). The fan is an Imperial 220618 - that's the one for my multi-belt 4.2 - serpentine is the opposite version. It still uses the stock fan clutch but eliminates the exploding plastic fan. There is an aftermarket fan and clutch that fits - I think you'll find that info. with a quick search on Pirate.
SC
Old September 14th, 2004, 04:47 PM
artm
Arthur Maravelis
97 SW
If I were to install electric(s) I would definitely add a sensor circuit to warn me when one's dead. I don't know if that's a standard feature but it should be.
Old September 14th, 2004, 06:16 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I thought about adding a sensor circuit and I might do that later. For now I figured having two fans would be good enough - slim chance of both failing at the same time and I think even one of these things could keep the engine cool (the two of them really cool it down quick once they fire up).
Old September 15th, 2004, 10:02 PM
You will know when they stop, they are very noisy and you can hear them over the engine at idle, but I would wire each fan on it's own, so if you break one then the outher keeps going.
Old September 16th, 2004, 02:53 AM
slowpoke496
Bryan
94
Good write -up on install
BrknRvr,
take a looks at the write up in the Custom Mods link. Very useful!
http://www.defendersource.com/mod/fan.html
Slowpoke496
PS
I too got mine from Summit.
Old September 16th, 2004, 02:16 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I got mine from the corner auto parts store - actually they are two single fans rather than one unit in a plastic housing. That is certainly a more involved installation in that writeup than need be, IMHO, though it is perhaps sturdier. The little fasteners that go through the radiator work fine & seem to hold the system in place nicely.
The included radiator-installed fan swich (thermostat - on at 189F, off at 168F) seems to work fine, though I'd like to change to one perhaps on the thermostat housing w/o giving up the air conditioner cutoff switch. Something to be worked out later.
I have some pics of the installation I can post if anyone is interested.
Old September 20th, 2004, 08:37 PM
souza's Avatar
souza
Dave Souza
1995 Defender 90 SW #275
I'm interested in seeing the pics... post away!
90, fan, flex
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
remove flex fan scoloco Defender Technical Discussions 9 October 13th, 2005 10:28 PM
Flex Fan (Clutchless Fan) NashvilleRedD90 Defender Technical Discussions 3 June 12th, 2005 03:09 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
