Flat Towing/Dolly - Auto D90 - Defender Source
Old August 15th, 2008, 08:36 PM
pcscharfe
pcdefender
D90/NAS 110
Question Flat Towing/Dolly - Auto D90
I have searched the forum extensively and found a few threads with info regarding this, but no solid conclusions for an automatic. Any advice you can offer would be greatly appreciated. I would love to know all my options before Moab. Thanks in advance!
If a car hauler is not an option...
For an automatic, is there a fool-proof way to ensure that the truck is not damaged or exposed to extensive wear using either of these methods for a long-haul (ie. 2000 miles) ?
FLAT TOWING or DOLLYING
1.) I would love a definitive answer about the "procedure" for doing it correctly for an auto.
2.) What are the "disadvantages" or potential hazards of each.
3.) Will either method add miles to the odometer?
Thanks!
Old August 15th, 2008, 08:51 PM
moose's Avatar
moose
Brett
Ex-Mod Tdi 110 Hard Top
To flat tow, just undo your drive shafts at the diffs, tie the loose end securely up out of the way, and you are good to go. No problem with the auto box and no miles added to the speedo. With a tow dolly, you would only need to disconect the drive shaft from the axle that is on the road.
Brett
Ex-Mod 110 Tdi
Series 3 88 Diesel Soft Top
Old August 15th, 2008, 10:40 PM
I agree...
Old August 16th, 2008, 12:46 AM
pcscharfe
pcdefender
D90/NAS 110
OK. The diff. should be disengaged, but should the gearbox be in "P" or "N" ? I have seen both recommended in other posts:
http://www.defendersource.com/forum/...eferrerid=1953
Old August 16th, 2008, 01:09 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
If the shaft is removed it won't matter what gear the trans is in since it won't be turning.
Jimmy Buffett
Old August 16th, 2008, 02:46 AM
4x4sche
john
73 SIII_ 97 D90_94 Disco
He means "UNBOLT" at the diff. ...........
You are better to unbolt the driveshafts.
Old August 16th, 2008, 01:59 PM
pcscharfe
pcdefender
D90/NAS 110
That makes sense. Thanks.
Old August 18th, 2008, 04:46 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
I don't have the manual with me, but I'm pretty sure all you need to do is put the transfer case in Neutral.
Old August 20th, 2008, 02:41 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Not if you dolly it.
When flat towing maybe, there is something about making sure the lubrification happens when the engine is off and other posts are addressing this.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old August 20th, 2008, 07:59 AM
galen216's Avatar
galen216
Galen Lentz
'98 D1
Look at your owner's manual. I flat-towed an RRC home this weekend. Transfer case in neutral and transmission in neutral, that was what the manual said. I have seen other people say transfer case in neutral, transmission in park, depends upon what type transfer case you have.
FWIW when I pull my Series I pull the driveshafts at the diffs too.
Old August 21st, 2008, 12:53 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
I got the manual open. For flat towing, transfer case and transmission in neutral, diff and steering column unlocked.
For suspended towing, disconnect the driveshaft, unlock the steering, but scure the steering wheel in the straight position.
90, d90, wing
WTB 97' D90 auto transmission cooler pendy Wanted 15 September 28th, 2005 08:12 PM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
how much can a d90 auto tow Kerr Defender Technical Discussions 10 December 10th, 2004 10:53 AM
How difficult is it to convert auto trans to manual in a D90? jaherring Defender Technical Discussions 14 June 17th, 2004 02:05 PM
