Flat towing - Page 2 - Defender Source
Old March 2nd, 2007, 08:52 AM
Chaucer
Will
93 110 | 97 90
Originally Posted by Davis
If you removed both drive shafts, why would it matter at all what gear you were in?
True enough.
Old April 13th, 2007, 09:44 PM
cdb
Clark Bowen
Rob....
regarding your comment:
"if the engine isn't running, the oil pump in the transmission isn't turning. For this reason, I would avoid extended flat towing"
If the transmission and t-case gears are not rotating what would be the problem with the oil pump not turning. Would the gears still need lubrication?
I'm asking because I'm considering extended towing of my 1994 D-90 and wouldn't want any damage
Clark bowen
Old April 13th, 2007, 10:42 PM
just disconnect your drive shafts at the pinion tie them up to the frame with rachet straps or bungee cords, no worries. I think it might be 12 bolts total.
wing
Flat Towing D-90 diffender Defender Technical Discussions 23 July 15th, 2011 12:25 AM
towing with a D-90 gofins Defender Technical Discussions 9 October 20th, 2005 11:53 AM
Towing a D-90 - Do I need a flatbed? arbik Defender Technical Discussions 4 January 27th, 2005 12:33 PM
D110 Diesel conversion, towing. Kerr Defender Technical Discussions 3 May 5th, 2004 06:26 PM
