flasher unit or turn signal switch - Defender Source
Old March 25th, 2016, 08:05 PM
akrockhound's Avatar
akrockhound
Jack
1988 RHD 110
Folks - 1988 RHD 110 v-8
looking for a little help troubleshooting a turn signal issue.
Turn signals quite - no noise, noise turn signals, no turn signal lamp on dash. NADA
The fuse is fine (tail lights and fan work on same fuse).
How can ? differentiate a flasher problem from a turn signal switch problem?
Turn signal switch is 2 yr-old lucas. flasher unit is Hella TB-64 (PRC8876)original?
Could change both but if these symptoms point to one or the other it would help
PS - horn and high beam on the same switch as the turn signals work fine - so there appears to be power to the switch
thanks
'88 ROW 110 5-door SOLD
'01 Disco II
'95 RRC LWB
Old March 25th, 2016, 08:11 PM
Hose down the internals of the hazard switch with some contact cleaner for starters and cycle it several times. My money is on it is dirty inside or corroded.
Old March 25th, 2016, 09:05 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
I ended up replacing hazard, light, turn and washer stalks/switches. 20 years makes for a lot of wear and you can get new stuff for not much $$. Makes things look nicer.
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old March 25th, 2016, 09:08 PM
akrockhound
Jack
1988 RHD 110
you are a miracle worker
Javelinadave - you are freakin genius........I flipped the hazard switch few times and the turn signal is working perfectly now.......I'll clean up the hazard switch.
This is why I love this forum!!!!!!!!!!!!!!!!!
'01 Disco II
'95 RRC LWB
signal, switch
Turn signal switch Jpayne Wanted 0 June 22nd, 2011 08:11 AM
Turn Signal switch may be shot- scout159 Defender Technical Discussions 2 March 11th, 2010 08:09 PM
94 Defender Turn Signal/High Beam switch Davis Wanted 2 May 18th, 2007 07:00 AM
Flasher Unit LED turn signals rustydefender Defender Technical Discussions 2 November 14th, 2006 09:28 PM
Need Turn Signal Switch 48vphantom Wanted 1 September 24th, 2004 02:18 PM
