Flasher Relay Part Number for 97 d90? - Defender Source
Old May 20th, 2010, 12:07 PM
KKilo23's Avatar
KKilo23
Kenny
Need to replace the flasher relay, before I pull the console apart I'd like to buy the part. Does anyone know what the part number is?
Thanks.
Old May 20th, 2010, 01:27 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Thanks.
According to this Post: CF13GL-02
~Scott T.
'95 D-90 ST - AA Yellow
Old May 20th, 2010, 07:28 PM
KKilo23's Avatar
KKilo23
Kenny
Scott thanks, I think that is for the LED conversion though...
Old May 20th, 2010, 09:45 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
The only difference between an LED-compatable relay and the stock relay is the lack of a burn-out sensor on the flasher circuit. The burn-out sensor looks for a drop in current caused by a burnt-out bulb and flashes the blinkers more quickly to alert the driver to the burn-out. The LEDs use less current and trips that circuit.
I'm running an LED compatible relay with a mix of LEDs and incandescents and it works fine.
For what it's worth, the CF13GL-02 didn't work in my 1994 truck. Whenever I engaged the turn signal, both sides would blink, as if I had the hazards on.
I ended up buying an LED-compatible relay from Auto Zone that works. That said, the relay I bought refused to blink when I was running LEDs front and rear. I had to revert to incandescents in the rear to get enough current draw to trip the relay.
90, 97, 97 d90, d90, part, relay
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
Part number for front marker lenses? Hans Misc. Chit-Chat 4 December 3rd, 2005 11:00 PM
Part number for 300tdi D90 steering wheel? dmarchand Misc. Chit-Chat 12 June 22nd, 2004 10:28 AM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
Part Number Cross Reference Database mlepisto Misc. Chit-Chat 8 December 19th, 2003 12:52 AM
