Fitting Vented Rotors - Defender Source
Old January 25th, 2009, 04:11 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
I am sorry if this has been addressed before, my searches turned up related details but nothing very straight forward on what is involved to go from solid to vented rotors on a non-NAS 110? Is is just a matter of swapping them in? (that would probably explain the lack of details).
Old January 26th, 2009, 12:28 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
I don't know all that is involved, but you will need either different calipers, or to 'rebuild' your current calipers with spacers, since the venter rotor is thicker than the solid one, the caliper from a solid rotor brake system will not fit around the venter rotor without modification. If the Rotor diameter is the same, I would imagine this would be your only real obstacle..
~Scott T.
'95 D-90 ST - AA Yellow
Old January 26th, 2009, 01:10 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I'm not familiar with the non-NAS 110 brakes, but if they are the same as NAS, I believe all you need is what Scott said. The pads and rotors for a D90 and either the calipers off the 90 or the spacers for your calipers. George at RDS carries the spacers and longer bolts to reuse your calipers.
Old January 27th, 2009, 01:53 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
I talked to George about these just before Christmas, and he said he no longer carried them. I thought someone else was doing this as well. Maybe check with Keith at Rovertracks or Bill at GBR.
Old January 27th, 2009, 03:06 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Hmm, I thought he said he could still get them though. Anyway, I talked to him around the same time (probably because we read the same thread) and he said he did have core D90 calipers available. He said they were complete calipers, but need a rebuild kit fitted to them. Could always go that way if you can't find a used set on one of the forums.
Brembo Rotors on eBay Glenn_Guinto Defender Technical Discussions 15 March 29th, 2005 05:11 PM
DBA Rotors... CDN38 Defender Technical Discussions 10 February 28th, 2005 01:47 PM
Gray Vented Dash Panel bugula Wanted 5 April 22nd, 2004 03:21 PM
Rotors Campbell Defender Technical Discussions 2 April 1st, 2004 03:23 PM
fuel tank skid plate, bumper, & rotors tonymotosource For Sale - Parts 11 January 26th, 2004 01:20 PM
