Fitting VDO Speed Sender - Page 2 - Defender Source
Old March 9th, 2011, 06:46 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
does anyone know if YBE100530 hall effect sender will work with a LT77s/LT230 and a TD5 speedo?
It looks like it would work at the T/C case
Old March 9th, 2011, 07:11 PM
Google "wibbly wobbly speedo"
Old March 9th, 2011, 07:36 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
very helpful,
thanks
Old March 10th, 2011, 02:08 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Who has a Landy that goes fast enough to need an accurate speedo?
Tony
1984 110 "Smokey" (sold)
Old March 10th, 2011, 05:15 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I worry about speeding, In school Zones!
Old May 22nd, 2011, 05:31 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Part# for Connector
Does anyone have a part number for the connector that connects to the YBE100540 sender? It's supposed to be a male connector that fits into the female connector on the sender. I've searched ebay.uk but can't find anything there or in the parts manual. Thank you in advance for your kindness.
Old May 22nd, 2011, 06:04 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
http://www.bmotorsports.com/shop/pro...oducts_id/1677
Worked perfect for the 3 wire sender.
i got the one with the pigtails
Old May 22nd, 2011, 06:06 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I don't think that will work with the YBE100540. See attached picture. It needs to be a female connector (?) that accepts two prongs into it.
Old May 22nd, 2011, 06:24 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I found it!
STC1188
Nevermind. That won't work I just learned from this thread: http://www.defendersource.com/forum/...eferrerid=4450
Old May 22nd, 2011, 06:38 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I just remembered that those don't work, you have to use the 3 wire one and leave the center wire out.
If you look at the sender, there is a space between the spade like things. the stc1188 holes are too close together.
http://www.defendersource.com/forum/...&highlight=vdo
this explains it better.
Old May 22nd, 2011, 06:40 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I just found that thread that says it won't work. Sounds a little strange to use the 3 wire one. What do you do with the 3rd wire? Pull it out? Did you end up using the STC62071?
Old May 22nd, 2011, 06:55 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I got the plug from the link I added with the pigtails. I have one of those senders laying around somewhere and the extra plug I bought, I can confirm they work for you as far as mating.
I actually used the 3 wire hall effect in my truck.
Old May 22nd, 2011, 08:09 PM
You need the 3 wire plug with either sender. I have one here to prove it!! It is the normal late model stop light plug for Defenders, STC4637, easy to get from any normal Land Rover parts source.
Old May 22nd, 2011, 09:00 PM
See photo of STC4637 and YBE100540
ID:	39001   Click image for larger version
Old May 24th, 2011, 09:18 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks!
Old August 8th, 2011, 12:32 PM
Originally Posted by don View Post
Method 1:
Is there a way to get the speed sensor for less than a hundred dollars? That's crazy money!
Old August 8th, 2011, 01:51 PM
For new, you should be able to get it a lot cheaper than that. The YBE100530 may be cheaper and is better built.
Alternatively, get one from a junkyard. There are many Discos in the junkyards.
Old August 8th, 2011, 04:53 PM
Thanks John
Old August 8th, 2011, 05:13 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I got mine from British Pacific. Can look up price. It was a great deal.
Old August 8th, 2011, 09:10 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I'd give Will Tillery a ring (http://rovaguy.com/) or hit up Trevor @ Rovah Farm (http://rovahfarm.com/) when he reopens on the 15th. I've gotten some very nice prices on things from both of them.
Tdi VDO oil pressure sender help Uncle Douglas Defender Technical Discussions 15 August 1st, 2014 11:08 AM
200tdi VDO Sender Part Numbers Wolf Fabrication Defender Technical Discussions 6 February 26th, 2011 03:55 PM
Has any one installed a VDO oil pressure sender on the '97 - 4.0? LenB Defender Technical Discussions 8 March 29th, 2010 12:30 PM
VDO Temp Sender (97 D90) nmc Defender Technical Discussions 0 September 10th, 2009 12:01 AM
VDO Speedometer mgrgpg Defender Technical Discussions 6 December 17th, 2003 08:26 AM
