Fitting trailer harness to NAS rear crossmember - Defender Source
Old April 29th, 2014, 09:41 AM
So as we all know, the NAS version doesn't have the big hole in it to fit a recessed and protected 7 pin harness socket. so what have people done to fit on that is well protected off road? Would it be as simple as drilling a big hole in the outer wall to fit one on the inner wall?
Mark Kellgren
KM4BOR
Old April 29th, 2014, 10:42 AM
Not sure if this is the same plug-in that you'd be using as it's the Euro trailer wiring, but essentially this is what I made up (with the help of Briggs providing the other end of the factory harness). It plugs right into the factory wiring on a NAS 90, and essentially allows me to run all of the factory lighting options on the Sankey (including the separate tail/brake lights & turn signals, marker/running lights, etc). Most American trailer wiring has the turn signals and brakes on the same circuit - which is not the case with the UK stuff.
Old April 29th, 2014, 10:45 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
That's right...you go boy...get that truck ready!!
Old April 29th, 2014, 11:14 AM
to be clear, I have nothing to pull, but I would like the add the ability to pull just about anything unforseen, and a standard 4 flat pin wouldn't cover electric brakes and charging a trailer battery would it?
I was also referring to location. If I added the Euro socket, would cutting a hole be the best approach for that?
Mark Kellgren
KM4BOR
Old April 29th, 2014, 11:29 AM
You are correct, no electric brakes/etc with a flat-4. You could easily mod the factory harness (like the pigtail I used) and put a US 7-pin trailer adapter on the other end as well.
As far as mounting...well, not sure if you are running a NAS bumper (though probably not), but if you are there are a plethora of mounting options. If you're not (as I am not), I actually just opt for the "plug it in as needed" method. Mine does not stay mounted, but lives in the truck. When I need to hook up the Sankey/etc I just reach under, disconnect the existing pigtail, and plug mine right in and I'm good to go.
Old April 29th, 2014, 11:33 AM
Nope, I got rid of my factory bumper day 1, so just an NAS xrossmember, which has no trailer harness hole.
Mark Kellgren
KM4BOR
Old April 29th, 2014, 11:53 AM
my crossmember. no harness hole
Mark Kellgren
KM4BOR
Old April 29th, 2014, 12:36 PM
Same dilemma. Been considering a plastic body mounted under. Hate to add a hole but it might be the best way forward. There are plenty listed on etrailer. You can also get adapters from 7 to 4 pin
https://www.etrailer.com/dept-pg-Wir...c-7_Blade.aspx
nas
Rear Crossmember & Fuel Tank Cradle for NAS D90 question Rufus Defender Technical Discussions 53 November 29th, 2012 10:54 AM
Replacing Rear Crossmember on a NAS D90 Manimal Defender Technical Discussions 7 May 21st, 2011 02:59 AM
Replacing the rear crossmember in a NAS 110, what do you do with the "saddle" evilfij Defender Technical Discussions 21 June 2nd, 2010 07:54 PM
Folding rear step on NAS rear crossmember Overlander Defender Technical Discussions 4 September 15th, 2008 09:33 PM
94 D90 wire harness & 94 A/C wire harness mdmuf Wanted 1 August 24th, 2007 09:33 AM
» Defender Registry
Tina
UtahD90
Bertha
TOZROVR
Add your Defender
