Fitting OME Steering Damper - Defender Source
Old June 19th, 2015, 11:03 PM
RBBailey
RBBailey
1965 IIa
Always the easy jobs....
So the OME steering damper for Disco 99 and on (going on my 2004) but it does not fit in the bracket to get bolted in -- that is, the bushing is too wide for the mount, by at least 1/8 inch. Unsure if I should try to just grind this down, or....?
Project:
1965 IIa SWB
Old June 19th, 2015, 11:12 PM
Post up a picture or two if you can.
Old June 19th, 2015, 11:16 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Is it eye-eye? Did you twist it correctly?
Old June 19th, 2015, 11:27 PM
RBBailey
RBBailey
1965 IIa
Both ends have same eye. Both have same type of bracket.
By the way, I could pry the bracket at one end, but don't have leverage to do the other end without figuring some odd tool set up to use. But I already bent the bracket out a bit, and it still won't fit in there. The bushing has a metal sleeve in the center, this is what is too wide for the bracket on the truck.
Project:
1965 IIa SWB
Old June 19th, 2015, 11:57 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Either beat the gap open in the bracket with a hammer, or grind down the bushing sleeve.
Old June 20th, 2015, 12:20 AM
I would grind down the bushing sleeve before I would deform the bracket. Actually there is no way I would mod the frame to bolt on an accessory.
Old June 20th, 2015, 12:28 AM
RBBailey
RBBailey
1965 IIa
OK. Seems I have some grinding to do. Thanks for advice.
Project:
1965 IIa SWB
Old June 20th, 2015, 01:25 AM
RBBailey
RBBailey
1965 IIa
5mm difference in the width of the standard compared to the OME.
Project:
1965 IIa SWB
Old June 20th, 2015, 01:29 AM
That's nothing. 2.5mm off each side of the bushing and you're good to go.
OME SD32 steering damper Landy_Andy For Sale - Parts 2 December 31st, 2013 04:05 PM
OME SD32 steering damper Landy_Andy For Sale - Parts 3 June 4th, 2013 10:58 AM
DII RTE HD steering linkages w/ OME Steering damper Jymmiejamz For Sale - Parts 3 May 22nd, 2013 12:03 PM
OME Steering Damper Nut Sergeant_V Defender Technical Discussions 2 September 10th, 2006 04:16 PM
little piece that steering damper mounts to near pitman arm evilfij Wanted 4 October 5th, 2004 08:55 PM
