fitting new style steering wheel to 110 - Defender Source
Old October 5th, 2010, 10:27 AM
discotdi
Todd Miller
Land Rover
Can the new style "fat" grip steering wheel be swapped into an old 110 with the giant 18 wheeler size wheel? 1985 110.
If so what is needed to do the swap?
Thx
Old October 5th, 2010, 11:31 AM
Remove nut and pull...
There are two spline types. You need to make sure the new one matches your splines.
Read here: http://www.web-rover.co.uk/nav.php?p...steeringwheels
Old October 5th, 2010, 02:57 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
If you do not have the correct spline end, you can buy the correct shaft (alone) and swap it in. Very easy to do and requires no dash disassembly.
Old October 5th, 2010, 08:06 PM
discotdi
Todd Miller
Land Rover
thanks for the info. still looks like it could be a bit confusing but will check the steering wheel splines etc.
Old October 7th, 2010, 09:28 AM
andyrad
Andy Radlgruber
None.
I used a Moto Lita wheel and adapter and I love it. The bus steering wheel just didn't work for me being 6'5". The turn signal is a bit farther away but the overall driving experience is fantastic.
ID:	31948   Click image for larger version
Some people are so heavenly minded that they are NO EARTHLY GOOD!
Old October 7th, 2010, 09:48 AM
I had the small size Momo wheel in my 83 110. Gave me lots of room and made the steering response very tight. My friends all said it looked like a go cart wheel in a shriners cart. My brother has an 83 with a late leather XS steering wheel-bolted right on. I have the 90's column now with the "fat wheel" and am think of switching it out for more options.
Old October 7th, 2010, 02:01 PM
discotdi
Todd Miller
Land Rover
John, thanks for the website link it was very useful. Way better than the WS manual. you seem to be a wealth of info. thx!
Old October 9th, 2010, 08:36 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
So I could pull the shaft out of my 1983 and fit it to my later model column relatively easily? So I could fit the small diameter wheel
Old October 9th, 2010, 08:49 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Yes. Knock the retaining pins out on the engine side of the firewall. Then pull it out back through the cab.
Old October 9th, 2010, 10:26 PM
Hadn't heard this one before. Any one got pictures ?
Old October 11th, 2010, 12:25 PM
Kev Baldwin
Kevin Baldwin
2.4 Tdci 110 Utilty Wagon
The NAS style ' fake airbag' style wheel will fit straight onto your column. Both are 36 splines. Except if the wheel has come from a late model Puma model, that in true LR tradition it could be either a 36 spline or 48 spline. Only the very latest PUMA models have the airbag wheel in 48 spline. If you are looking at buying a second hand wheel from a NAS then it's save to say it'll fit your 85 truck.
The turn signal and wiper control stalks can be bent toward the wheel to make them within fingertip reach of the wheel. Grip with one hand at the base of the stalk and then bend with your other hand as close to the base as possible. This is the method we use all of the time when fitting wheels and have never bust a stalk...yet!
Old October 11th, 2010, 03:55 PM
discotdi
Todd Miller
Land Rover
thanks Kev.
Old October 11th, 2010, 04:21 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I'll post some pics later this week when I get back to the shop. Think of it as removing the inner splined section of the shaft from its' outer casing.
110, wheel
removing steering wheel Hollywood Defender Technical Discussions 25 August 15th, 2010 03:16 PM
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
Steering Wheel Sleeve mpodgorski Defender Technical Discussions 5 December 12th, 2005 10:46 AM
