Fitting led headlights to ex-mod - Defender Source
Old September 20th, 2014, 01:59 AM
Hache
Henry Lambert
1983 Ex-MOD 90 2.5N/A
Any one tried doing this? I know they will work and fit, but don't I know if they'll fit in the sealed rubber cup behind the light or whether to remove this.
Thanks!
Old September 20th, 2014, 02:14 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
No, you will have to replace the entire H4 assembly and possibly wiring and the mounting ring, depending on what you have.
IMHO, LEDs look ridiculous on Defenders, especially ex-MOD trucks. I went for a Hella H4 halogen bulb with the heavy duty ARB wiring harness. I had to build some harness adapters and replace some bits because of the sealed mil bulbs in my Tithonus but it was an easy afternoon project. End result is super-bright headlights that don't look like some street racer degenerate.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old September 20th, 2014, 08:21 AM
Hache
Henry Lambert
Thanks Chris. You're going to hate my 90!
The mounting ring and wiring is the same I think. It's the plastic and rubber stuff that keep everything protected that may be too shallow
Old September 20th, 2014, 08:44 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Don't mind Chris, Henry. Chris thinks he's a purist. LED's look ridiculous alright... Ridiculously awesome. Especially on an MOD truck. More important than what they look like is how they work. They have a much lower draw, the light quality and disbursement is better and they'll outlast the life of the truck. Which brand are you going with?
Old September 20th, 2014, 08:47 AM
Hache
Henry Lambert
The truck-lites. Everyone here seems to love them and I really like the look of them.
Old September 20th, 2014, 08:56 AM
the rover shop
shayne young
I've always converted my trucks to the halogen units with the hella lenses..you can get them pretty easily off eBay and they work breat and if you give them a better power feed they are very bright..they make a headlight relay system which uses the headlight wiring to switch relays to five a really good power to the lights and reduces the load on the switches.. And they look stock for the purists.. this next build I will be using the trucklites.. I'm choosing function over appearances, I think they look totally out of place (and a little ugly) but are supposed to give totally awesome light projection..and that's more important for this one to drive around the world..
Old September 21st, 2014, 04:37 PM
Hache
Henry Lambert
So I used the existing MOD fittings but removed the small weather cover from the connector to make space for the larger trucklite assembly. It all works. I'm just a little nervous that the LR design has just one screw holding the headlight surround to the body work as the trucklites are heavier than the stock lights.
Old September 21st, 2014, 04:50 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Got a pic? I don't recall any surround or plinth that just has one screw.
Old September 21st, 2014, 11:09 PM
Hache
Henry Lambert
The surround has 3 screws to the lamp but then only one screw to the body. You can see it at 2:09 in this video:
I'll take pic tomorrow.
Old September 21st, 2014, 11:17 PM
rankar's Avatar
rankar
Ok you're actually talking about the headlight itself, not the surround.
Your fine. It's not coming out. If you're still worried, then put some blue thread lock on the screw.
Old September 21st, 2014, 11:28 PM
rankar's Avatar
rankar
I would solder the connections, not use a connector as seen at 11:30
ht, lights, mod
Mod-90 headlights set Hache For Sale - Parts 1 September 17th, 2014 01:03 AM
Truck lite LED headlights josh-man For Sale - Parts 18 July 22nd, 2014 09:56 AM
Pot heads stealing Range Rover LED headlights Rocky Misc. Chit-Chat 3 May 13th, 2014 07:19 AM
Truck lite led headlights NikosF For Sale - Parts 3 April 3rd, 2013 09:52 PM
NO Headlights - Fuses All Good/MOD pls Delete BlackDog Defender Technical Discussions 0 October 10th, 2009 11:45 AM
