Fitting D110 Body Capping - Defender Source
Old November 1st, 2006, 08:06 PM
mattarm's Avatar
mattarm
Matt
1993 D110
So I removed the top and am in the process of replacing the rusted body capping on my 110 and the new parts just dont seem to line up very well, or in some cases at all. Is there a variety of different types of 110 body capping? The part seems visually similar to those that I took off, however require quite a bit of persuation to put on and seem to ride too high when lining up the rivet holes on the side (so much I dont think those ont he top would grip). Any help would be very much appreciated.
Matt
Old November 1st, 2006, 08:12 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I replaced one whole side of the loadbed on my D90...wheelbox & all. Parts made several years apart may have to be persuaded together. Hammer to fit, paint to match. If it looks right and it works, then it's right. Self drilling screws can be used to temporarily fix things in place and be removed one at a time and replaced with rivets for final assembly.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old November 1st, 2006, 09:05 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Rob,
I can appreciate issues with the age differential between parts and the need for some manipulation.
As you can see side by side there are minor differences in the portion of the capping that attaches to the inner bed. On the new part, this section is slightly longer (see photo). Seemingly no big deal as for the most part the are pretty similar.
My larger concern is that when positioning the body capping so that the holes on the sides (vertical bed) line up with the capping, the top (horizontal surface) appears to look at least a quarter inch too high. The problem is compounded by the fact that the rivet holes on the top are about 1 inch off in some places. As you can see in the other photo, these are not even close.
Loaded 3rd photo just to compare the parts from the same side of vehicle and holes also are not even close.
I cant help but think that I got the wrong parts...
Anyone have any ideas/info?
Matt
ID:	7272   Click image for larger version
Old November 2nd, 2006, 06:38 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I have replaced the cappings on several different defenders - both top rail and end. In my experience it is a simple drill out and replace. If you are going from a hardtop to soft top, there may be nutzerts to drill out, but for the most part, holes aline if you have the right parts. For the 110 there are multiple versions. Call George at RDS, he probably has what you need. Also, I use cleco clamps to align everything before pop riveting it into place. Same investment, but I use them all the time.
Old November 2nd, 2006, 08:24 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
The cappings are usually drilled at the factory per tub assembly. The best way to make the job easy is to galvanize your old cappings. If not it will take some drilling and such as the others suggested to make the new ones fit).
Email:
Old November 6th, 2006, 02:56 PM
mattarm's Avatar
mattarm
Matt
1993 D110
So, I have had my original cappings blasted and lets just say that one of them did not fair to well as it looks like some portions of it were being held together by paint and rust.
I would like to stay with an original style capping. Rovers North says that the only PN they have for the capping is ALR3154 & ALR3155.
If in fact there are several variations on the 110 body capping, can anyone provide any guidance on how/where I can locate a drop in replacement?
Old November 13th, 2006, 07:48 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Just to close the loop on this one in the event that the topic is searched, I wound up having a local fabricator refurbish my original body capping. Let me say that they look AWESOME. I wish that I would have gone this route in the first place. I also wish that I had taken some before pics just so you had an appreciation for the work that was done. I have included a few samples of the finished product and let me just say that the photos do not do these things justice. I am almost sad to have them galvanized as they are practically a work of art.
ID:	7396   Click image for larger version
Old November 13th, 2006, 09:31 PM
Billakris's Avatar
Billakris
Kris
Alpine White 95 Soft Top
Glad to see you finally got that figured out, Matt. Let me know if you need any help over Thanksgiving.
Kris
Old July 19th, 2010, 07:23 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Adding a few pics for Barry.
ID:	29501   Click image for larger version
Old July 19th, 2010, 07:43 PM
bjf's Avatar
bjf
barry f
94 ST #395
looks nice. I assume all the seals had to be replaced when you did it?
110, body, d110
D110 Quad Cab Body Parts kingstonman Wanted 5 October 15th, 2009 11:43 AM
What are the body capping options / differences? Hans Defender Technical Discussions 4 August 9th, 2009 12:49 PM
NAS D110 Plastic Spare Tire Cover Body Color Jon_Winningham Smaller Projects 6 July 24th, 2009 10:12 AM
rear 110 body capping WhiteD90 Wanted 10 May 6th, 2008 11:25 AM
body capping on rear tub WhiteD90 Defender Technical Discussions 5 October 6th, 2004 06:10 PM
