Fitting an handle to a tailgate...? - Defender Source
Old February 20th, 2007, 03:42 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Question Fitting an handle to a tailgate...?
I'm planning to convert the Cube from SW to truck cab (less "Cube" but I want to give it a try)...
As I have a complete tailgate (and a truck cab of course) as well I'd like to add an handle to it
and turn it into a swing-away tailgate,so to keep my Mantec tire carrier...
(I'll have to work out a quick release system so to use the rear winch when needed but that's another story)
Looking at the handle ,it doesn't split into separate parts...I wonder how those of you made it without cutting a window in the tailgate?
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old February 20th, 2007, 06:20 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Not sure I completely understand your issue, but the mechanism can be wiggled in and out of the hole in the tailgate.
Old February 20th, 2007, 06:50 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Lightbulb
Erm,
sorry it's not clear maybe...a couple of pics may help.
I want to fit #1 to my tailgate which doesn't have a slot like the SW door has (pic #2)...
So far it looks like I'd eventually have to cut the lever off with an angle grinder as it's welded on...
Michele
D90 VNTdi
[O]===[O]
Old February 20th, 2007, 06:28 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
The tailgate does have a hole and the handle will fit thru it. Question is whether you need to drill a hole for the lock. I will be at the shop Friday and can look at a SW and ST side by side (and my various parts books) to see if the mechanism is different - but at first glance it looks the same.
Old February 21st, 2007, 02:26 AM
Cube II's Avatar
Cube II
Michele
1997 D90
My tailgate came off a truck cab 90...I guess I'll have to detach the handle,drill the holes,fit the lock assy,re-weld handle...
Can you take a couple of pics on Friday?
TIA
Michele
D90 VNTdi
[O]===[O]
Old February 21st, 2007, 06:15 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Be happy to take some pics. I have a ST tailgate and the parts separated and sitting around. I was sure the ST tailgates and the truck tailgates were one to two types - drop down or swing. And the swing either had locks or didn't. But I have several types at the shop and will get you some photos.
Old February 21st, 2007, 10:46 AM
Monkeyboy
Guest
Posts: n/a
Primitive Pete here .... why not just leave the on on the left side and put hinges on the right ... ???
The existing tailgate already has an "anti-luce" pin top right and left, no?
Old February 22nd, 2007, 10:02 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Just for the sake of it
I have the "anti-luce" pins which came with the tailgate...but you can only fit the LHS one,
RHS doesn't fit anymore due to the Mantec tire carrier hinge...
The handle option looked better to me...I can always drop the idea if it gets too complicated...
Michele
D90 VNTdi
[O]===[O]
tailgate
Euro 90 Swingout tailgate / POE liftgate install dave_lucas Smaller Projects 24 March 14th, 2016 04:01 PM
Tailgate Subwoofer Box and Speaker boshea For Sale - Parts 9 December 21st, 2005 11:47 AM
Tailgate question tim Defender Technical Discussions 2 June 23rd, 2005 12:05 PM
'97 SW window handle crank J4hand Defender Technical Discussions 2 August 8th, 2004 08:51 PM
dual position tailgate on a SW artm Defender Technical Discussions 5 April 24th, 2004 12:03 AM
