Fitting 12" shocks - Page 2 - Defender Source
Old April 7th, 2015, 03:10 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Originally Posted by cellulararrest View Post
Not really sure how that's possible. But what springs are you running? Older safari gards? I'm about to put some in my truck and that may change my opinion - haven't done the measurements yet. But I have a good 2 - 3" of extra droop when I take the top retainers off currently.
I'm running 225lb rate 3.5 rears older RTE's on a 1" spacer and 300lb 4.5 " front .
Small diameter wire coils extend pretty easy .
85 D110 3.5 3 DR
Old April 7th, 2015, 07:04 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Originally Posted by Arcadeus View Post
I'm running retained with 14" sb's
Me too with 3" springs
Legend in My Own Mind.
Old April 7th, 2015, 03:03 PM
shanecl
Shane
Def 90 4.2 v8
What do you mean when you say retained
Old April 7th, 2015, 03:06 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
You aren't using a cone system to allow the springs to dislocate. Both the upper and lower part of the spring is fixed to its seat so it spreads apart as the axle articulates.
Old April 7th, 2015, 11:37 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
So I know the old RTE springs were designed for this where they had coils of varying thickness so they would stretch. The RTE springs I have, the newer ones, would never stretch far enough. At least I can't imagine they would. Even now, with shorter Fox shocks I probably get 5 inches of dislocation on the cone. There is no way that RTE spring is going to stretch 5 inches with just the weight of a 33 inch tire and rim pulling on it. Unless there is something i'm missing... I hate the sound the cones make so I'd love another alternative.
Old April 8th, 2015, 04:24 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Yes agreed on the newer coils , but there's more than just the weight of the tire involved . Your tire is out board of the coil so there is some force being put on the dropping coil from the opposite side tire. I run 37" tires on my 90 so there is a little more leverage involved .
85 D110 3.5 3 DR
" Wolf " Style Steel Rims 6.5" X 16" 2 3/4" javelinadave For Sale - Parts 3 January 27th, 2014 08:36 AM
Wanted: SW Roll Cage RH "horn" or POE "horns" JimC Wanted 8 December 5th, 2006 03:35 PM
"94" RRC SWB County $9,500 "ish" shawom For Sale - Vehicles 0 October 18th, 2005 08:39 PM
Difference between "WOLF" and "NATO" wheels? wicks Defender Technical Discussions 10 August 12th, 2005 04:23 PM
OME springs: "A" and "B"?? jaherring Defender Technical Discussions 3 October 30th, 2004 05:49 AM
