First Time 110 Short Cab Canvas Install - Defender Source
Old June 15th, 2013, 08:29 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Will be installing a 110 short cab canvas this weekend and based on what i could figure out without any instructions, there are 4 spring clips that hold the front piece in place above the windscreen which allow the edge of the top to go underneath.
It looks kike my metal front windscreen strip has never been drilled for the four clips.
So am figuring that it will need to be GENTLY clamped in place, drilled and the clips inserted so the black plastic lever goes under the top of the windscreen frame with the locknut on top of the metal front windscreen strip (that is added for the canvas). In other words the plactic lever goes at the very bottom with the locknut at the very top of the whole front assembly.
Anyone want to provide a sanity check who has been "down this road" before?
Did several searches in the archives before making this post and came up with lots of posts on canvas seat covers, but nothing on this subject...
RDavisinVA
Old June 15th, 2013, 11:14 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Yup, you've got it right.
That's the standard front rail clamp. I can measure the one on my 90 in a bit if you want (got a euro military canvas on it)
The black plastic lever, as you rightly say, goes at the "bottom", kind of sits up inside the lip of the windscreen frame. Think it's an 8mm hole that you need up through the windscreen frame and up through the clamping "header bar". between the top of the windscreen frame and the underside of the header bar, the spring goes in.
Then on top, is the washer and nulock nut.
It should be set up so that the nut is loose enough to just un-clamp the header bar, and clamp it down again, but (here in the UK) the canvas is so rarely removed, i tighten up the nut with a spanner as well (doesn't have to be silly tight) just to give an extra bit of seal on the header bar.
------ Follow up post added June 15th, 2013 04:16 PM ------
Added:
http://www.allwheeltrim.co.uk/Frames.html#header-rail
This site will show you some pictures of what's done. They're a great company, not too far from me either, it's where I got all the bits for the latest project.
Old June 15th, 2013, 12:46 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Thanks.
I am good now!
RDavisinVA
110, canvas
110 Crew Cab conversion TravelerBT Defender Technical Discussions 47 December 15th, 2015 10:23 PM
110 Double Cab maxwell Misc. Chit-Chat 25 December 13th, 2013 03:24 PM
Diamond the Dormobile 110 evilfij Truck Build-up's & Restores 85 May 31st, 2013 09:14 AM
110 Double Cab spotted in Paramus NJ Yesterday TDI Guy Misc. Chit-Chat 3 September 27th, 2009 09:23 PM
Defender 110 Hi Cap Bed and Truck Cab FS SafariHP The Vendors Loft 2 April 14th, 2009 06:34 PM
