First Post Here - D90 Audio Wiring and Advice - Defender Source
Old October 12th, 2004, 12:17 PM
Kimos's Avatar
Kimos
Larry O'Hara
1997 Defender Wagon
Question First Post Here - D90 Audio Wiring and Advice
Have posted a couple of times on RN - with no response. Hoping to find assistance and offer same on other issues here.
Have a 1997 D-90 Wagon - has a clarion amp and a aftermarket head unit. Replacing faulty unit with a Clarion CD. The old (pioneer) seems to be wired through the factory amp.
Can anyone advise the wattage of the factory (clarion) amp?
Is it better to bypass and use new head unit power?
Does someone have the audio system wiring diagram? Thanks!
Old October 12th, 2004, 12:30 PM
Yeah you can bypass the amp, if I had time/money and really cared enough to do it I would try to remove the entire radio/amp/wiring and replace it with my own componets. I think new factory head units offer sufficent power depending on your requirements.
www.d-90.com/faq/Interior/IntRadio.html#Pins
there is some good information in the FAQ, no diagrams but there is enough information to figure out what does what. ALso you may want to consider mounting your CD player vertical in the cubby I think this is an issue with most CD players.
Old October 12th, 2004, 12:44 PM
Kimos's Avatar
Kimos
Larry O'Hara
1997 Defender Wagon
Audio Wiring
Thanks for that data! Perhaps the pin outs will be enough.
I am replacing the Pioneer (prev owner rigged in) with a Clarion that is 55x4 watts. I know I can just connect the line level outputs from it to the wiring in the console as is and use the Clarion (OEM) amp. I was hoping someone knew the wattage so I could make an educated decision.
I do intend to change more of the system out in the future but was wanting to just replace the head unit while I have it apart. I am replacing the floor bolts (stainless), carpet sections, shifter plate etc. . .
Old October 12th, 2004, 01:17 PM
Some old posts that cover some of this.
http://www.defendersource.com/forum/...ead.php?t=1193
http://www.defendersource.com/forum/...ead.php?t=1795
http://www.defendersource.com/forum/...ead.php?t=1558
http://www.defendersource.com/forum/...ead.php?t=1513
90, d90, wiring
Late td5 dash wiring cabell Defender Technical Discussions 43 May 18th, 2013 08:22 AM
Rally Light Wiring: ROUTE THROUGH ROLL CAGE pcscharfe Defender Technical Discussions 2 September 8th, 2009 04:15 PM
rover wiring frustration akfisher Defender Technical Discussions 6 December 16th, 2008 01:09 PM
Cleaning up wiring ideas? Abrooks Defender Technical Discussions 8 February 20th, 2008 10:39 PM
