Fire Extinguisher - Defender Source
Old August 8th, 2007, 02:48 PM
bjf's Avatar
bjf
barry f
94 ST #395
Fire Extinguisher
I want to get a fire extinguisher in the event my defender decides to ligght itself on fire. Nothing too crazy just something to mount to the roll cage behind the center cubby box. Any idea?
Old August 8th, 2007, 02:54 PM
efournier
Eric
'95 D-90 ST
I got one from these guys. Also got the two strap braket to make sure it stays in place.
I mounted it in front of the seatbox.
I/O Port Racing
Old August 8th, 2007, 03:04 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
ABC chemicals are highly reactive and will destroy a lot of your truck while you try to save it, consider a halotron extinguisher. They are filled with recycled halon and leave no residue.
Old August 8th, 2007, 03:35 PM
Firefighter2904's Avatar
Firefighter2904
jason
97 d-90
Kevin is absolutely correct. If you get an ABC extinguisher and fire it off in the engine compartment, prerpare to have your whole wiring harness be junk. The dry chem will destory all rubber bits as well as wiring. Definetly consider a halon extinguisher. A bit more money but definetly worth it!.
halon extinguisher are the way to go. that's what the military uses in tanks. halon extinguishers are commonly available through pilot supply retailers, since you don't want to damage the plane or electronics further while flying and putting out a fire.
Old August 8th, 2007, 03:37 PM
bjf's Avatar
bjf
barry f
94 ST #395
so i take it the link to the first one is a bad idea?
any links to where to get one?
Old August 8th, 2007, 03:56 PM
themaxx's Avatar
themaxx
Ade
94 ST
Actually if you click on that above link, you will then see a link to Halon extinguishers.
Cheers!
Another option: http://www.h3r.com/products/home_vehicle.htm
Old August 8th, 2007, 03:57 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Doesn't halon need to be in a contained space to be effective? Like a closed room.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old August 8th, 2007, 03:58 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Here. http://www.h3r.com/If you have an engine fire, do not open the hood , just stick the nozzle in the grill and empty the whole damn thing. Thats your best chance of knocking it out. It starves the fire best in an enclosed space.
Old August 8th, 2007, 04:02 PM
bjf's Avatar
bjf
barry f
94 ST #395
it seems the first one listed should be fine. it says it isnt abc and is the best cheapest alternative to halon
Old August 8th, 2007, 04:09 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Change out your oil cooling lines too. They are the biggest cause of Defender fires.
Chris von C
[/size]
Old August 8th, 2007, 04:27 PM
efournier
Eric
'95 D-90 ST
The one at IO Port is 10BC. (not ABC) Halon with a 10BC rating at H3R starts at $230.
I hate to have a little 2BC and not have enough.
YMMV
Old August 8th, 2007, 04:30 PM
Here's one from a major pilot supplier:
http://www.sportys.com/acb/showprod....tGroup_ID=1273
You'll notice closeup that they are H3R products.
Old August 8th, 2007, 04:54 PM
A cheaper choice than Halotron is Potassium bicarbonate (aka Purple-K). It won't hurt the engine and works well. Everything we use at work (refinery type setting) uses this.
FYI, "halon" is illegal to produce as it is a CFC.... The new stuff is "halotron".
Old August 8th, 2007, 05:08 PM
bjf's Avatar
bjf
barry f
94 ST #395
where can i get one?
Old August 8th, 2007, 05:28 PM
themaxx's Avatar
themaxx
Ade
94 ST
www.h3r.com
Old August 8th, 2007, 05:56 PM
bjf's Avatar
bjf
barry f
94 ST #395
thanks
Old August 8th, 2007, 07:04 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Interesting info in this thread. Thanks.
I was reading through the H3R site, and it seems that Halon really isn't illegal to use (per the EPA). However the production of new Halon was banned in 1994. Existing Halon supplies can be used as long as it's used properly and recycled. So the three main choices appear to be Halon, Halotron, and dry chemical. If you're environmentally conscious, then the choice narrows to Halotron and dry chemical. It's not clear to me whether the dry chemical variants (sodium bicarbonate, Purple-K, etc) will cause any engine compartment damage or not. So would Halotron be the best choice from most aspects (i.e. environmentally, damage potential, and effectiveness in dealing with enclosed space fires)? It's also moderately priced between Halon and dry chemical. Anyone know of any negatives regarding Halotron other than it's a little pricey (~$150 for 5 lbs).
Old August 8th, 2007, 09:27 PM
cdb
Clark Bowen
You might also consider the Hawke ABCDK AllFire Designer Foam.
Here's an RV website that discusses the various choices and the Hawke looked the best to me from a cleanup, cost and emulsifying petroleum products:
http://www.aonrecreation.com/ardhome...0Extinguishers
Clark
I thought this was relevant too:
http://macthefireguy.com/34_fire_fac..._save_your.htm
Old August 8th, 2007, 11:29 PM
LRover's Avatar
LRover
J. Michael McCaig
Don't forget CO2 in a BC extinguisher. It's rated for oil fires and won't harm electrical stuff.
fire
Make sure to secure your fire extinguisher evilfij Misc. Chit-Chat 20 May 5th, 2010 09:52 AM
Safecraft Fire Extinguisher - Polished SS + Billet Aluminum Bracket - Halon pcscharfe For Sale - Parts 9 August 7th, 2009 12:55 PM
Roll bar fire extinguisher holder Abrooks For Sale - Parts 2 July 16th, 2009 10:17 AM
Cool Quick Release Fire Extinguisher Bracket Wolf Fabrication Smaller Projects 1 December 19th, 2008 10:48 AM
Recommendation on a Fire Extinguisher - size, type, mounting, etc. COSteve Defender Technical Discussions 16 April 16th, 2004 02:21 AM
