Filters for 300tdi? - Defender Source
Old March 15th, 2007, 10:45 AM
nas110_300tdi
nas110_300tdi
NAS D110
Filters for 300tdi?
Hi all,
I have searched for answers on this and have not found much.
I am about to change the oil on the 300tdi - first oil change since I aquired it. What oil filter should I be using? Land Rover's part ERR3340? Would it be safe to use an equivelent?
Any recommendations for the fuel filter and fuel sedimenter? I've seen Racor mentioned on some threads here, but I'm confused between fuel filter by the tank and the sedimenter in the engine bay - or is it the other way around? Not sure which needs changed and at what interval. Any help here is much appreciated.
Thanks for your time.
Old March 15th, 2007, 11:04 AM
The ERR3340 is the same part number as the v8 filter - and before I bought a ten-pack I would just use the ones from Napa.
You can go to Napa and get the fuel filter for an 84 VW Rabbit diesel and its the same one. Napa is all I use since they're so available. I change them when I change the oil.
I dont have a separate sedimentor, but I thought those were just meant to be drained.
Old March 15th, 2007, 11:32 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Just adding to Jims comments...
The sedimentor is located next to the fuel tank in the wheel arch. There is a small white thing you can un skrew and drain. Thsi also works as a water seperator so drain in to a clear container and watch for water. If you want you can take it apart and clean it. All it does is unskrew the whole bottom portion and tere is a white screen kind of cone thingy that you can clean...Just drain about a half cup at ~2000-5000 miles and you should be fine unless you are having other symptoms.
Old March 15th, 2007, 12:27 PM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
A couple weeks a go I did an oil change on the 300tdi. When the time came to pull the filter I didn't have one. I did have a PH8A on the shelf that I keep for an old pick up. It worked fine.
8-track, gun rack, spittoon, gimbal mounted beer buoy, blah, blah, blah, blah......
Old March 15th, 2007, 12:29 PM
The sedimentor was optional, it may or may not be present.
Old March 15th, 2007, 01:32 PM
nas110_300tdi
nas110_300tdi
NAS D110
Thanks guys!
Old March 15th, 2007, 09:52 PM
Eddie 1's Avatar
Eddie 1
EDWARD BAHAW
Disco 1 TDI 300 SE
Purulator L30001
Old March 15th, 2007, 10:24 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Fram works fine too. I can get the part number if you care.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 19th, 2007, 01:46 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Racor makes excellent filters. I have a 500fg series in my Lightweight and will be putting one in my Defender too. You can get them that will alarm if the water level in the sediment bowl get's dangerously high.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 19th, 2007, 02:35 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Mine is set up with a Racor 460T separator with 10 micron filter (Thanks Matt) it fits the factory mounting holes and looks great in the stock location. Some day it might have fuel running through it if I ever get the rest of the thing together.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old May 2nd, 2011, 12:05 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Reviving an old thread.
For those who have tried different oil filters, in your experience which is the best one?
Is there one better than the ERR3340 filter?
Originally Posted by nas110_300tdi View Post
Hi all,
Old May 2nd, 2011, 12:21 PM
Sure, just get a PH8A equivalent.
Old May 2nd, 2011, 12:22 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Pardon my ignorance but whats PH8A?
I haven't changed my own oil yet. Now that I finally have a garage I decided to go for it.
What kind do you run, John?
Old May 2nd, 2011, 01:13 PM
Fram part number. At one time the most common filter in existence.
Oil? I use any of the synthetic 5W-40 or 0W-40 diesel engine oils. At the moment, the 90 has Mobil 1 Turbo Diesel Truck in it. Next change will be Shella Rotella T6 (there was a great deal on it in the fall and I bought a bunch). I used to use Esso XD-3 as it was the best price, but that changed.
Choice and pricing is a bit different in the States and I'm not sure what the best deals are. Both the Mobil 1 TDT and the Shell T6 are good choices.
I would suggest to everyone to get oil analysis performed. It does not cost much and will tell you a lot about possible problems with the engine and make sure you are changing the oil at the right frequency.
edit: I'll add that if you do live somewhere that is always warm one of the high quality 15W-40 oils may work as well for you. However, I would suggest doing comparison analysis to make sure this is true.
Old May 2nd, 2011, 07:30 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Where do you get an oil analysis done?
Old May 2nd, 2011, 09:07 PM
I get mine done at the CAT dealer, http://www.cat.com/maintenance-and-support/sos-services. There are a lot of places around. You also have a lot of choices for online and mail order service in the US.
Old May 2nd, 2011, 10:19 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
So back to my original question. From what you're telling me the oil filters are all the same, no one better than the other. Is that a correct assumption?
Old May 2nd, 2011, 10:23 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Uh oh, let the Holy War begin.
Old May 3rd, 2011, 01:35 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Tony
1984 110 "Smokey" (sold)
Old May 3rd, 2011, 09:25 AM
No there are good ones and bad ones..... Massive subject. Look for the premium level ones and you "should" be safe. There was (is?) a big study on the net, but it got out of date. I think is CAUSED improvements in filter construction.
On the fuel filter end, I run a 2 micron Stanadyne filter. There have been studies showing marked improvement in injector nozzle life by using better fuel filtration.
300tdi, tdi
Substitution parts: oil filters MonLand Defender Technical Discussions 6 January 25th, 2008 10:12 AM
International HS2.8L Filters DesertRat Defender Technical Discussions 3 August 7th, 2006 11:51 PM
OIL...oil...oil... norros Defender Technical Discussions 20 August 22nd, 2004 01:30 AM
Air filters and a bad fuel tank valve thingy! RickM Defender Technical Discussions 1 August 9th, 2004 03:29 PM
Who wants filters? dmarchand For Sale - Parts 0 May 27th, 2004 12:40 PM
