Filters for 300tdi? - Page 2 - Defender Source
Old May 3rd, 2011, 10:08 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I was going to order Coopers or Mahle. Would those be ok?
I have a .2 Micron Stanadyne as well.
Old May 3rd, 2011, 10:47 AM
Read here: http://minimopar.knizefamily.net/oilfilters/index.html I see there has been more recent work. Have a look the Toyota filer page as it is not "that" old...
Old May 3rd, 2011, 02:22 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
300tdi list
below is pasted the file I have on my phone for 300TDI part numbers, etc. There's an equivalent Bosch filter available, I just don't have the part number and not sure its worth double the price.
Oil Filter
Fram PH8A - Quaker State QS8A - LR ERR3340 - Purulator L30001
Fuel filter
AEU2147L - paddock/britpart,
Proline - plf862
Fram P1145A - (84 diesel rabbit)
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old May 3rd, 2011, 02:33 PM
I like the short filters. BTW, the PH8A, Motorcraft FL1A, etc etc is a Ford filter. They are longer than the ERR3340 by about an inch or so. Just sayin. Never had one get smacked but check your clearances.
Oil Filter
Fuel filter
Proline - plf862
Old May 8th, 2011, 07:45 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
WIX 51515 and Hastings/Baldwin B2 are both good filters (though the longer style) and I pay <$5 for WIX here.
For fuel I tried a Racor when I did my first diesel conversion in '82 and that's all I've used since.
Incredibly, in the 80's JC Whitney sold Racor FS200 filters with the high water level alarm for $65. Quite a deal.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 2nd, 2011, 12:05 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
John,
I'm afraid I'm too technically challenged to make much sense of this. There were some that seemed a little less good than others but no clear winners. Can (all of) you give me a list of your top 3 filters?
Old July 2nd, 2011, 12:30 PM
defeyago's Avatar
defeyago
Santiago
“96 Defender 110 VGTdi SW County
Do you have MANN filters there? Around here are one of the best available. Or you could use Donaldson also.
Regards,
SANTIAGO
“97 Defender 110 Tdi SW
“04 Freelander Td4 5 dr.
“97 Alfa Romeo 146 TD (Sold)
“95 Volvo 850 GLT Estate
“94 Discovery Tdi (Webasto equipped)
Old July 2nd, 2011, 02:08 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Do you have a part# for the Mann filter? Want to make sure I order the right one for a 300tdi.
What are people's opinion on K&N? I think that's the oil filter I have on there now.
Old July 2nd, 2011, 02:27 PM
defeyago's Avatar
defeyago
Santiago
Oil MANN W930/20
Diesel MANN WK842/2
MANN is what most of us use down here on our bunch of 300tdi“s around here. They are very good quality filters.
Cheers,
SANTIAGO
Old July 2nd, 2011, 04:52 PM
Originally Posted by Manimal View Post
John,
Clearly stated here: http://minimopar.knizefamily.net/oil.../opinions.html Anything under "recommended filter" is perfectly fine.
Old July 2nd, 2011, 10:39 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks. I read it. Was hoping for a clear winner but will pick any of these.
Old July 2nd, 2011, 11:04 PM
It does not really matter as long as it is decently made. You just don't want one that falls apart. Oil filters don't really do a lot. If there are particles big enough in the sump for a full flow oil filter to catch, you have bigger worries.
Old July 3rd, 2011, 12:30 AM
defeyago's Avatar
defeyago
Santiago
Here is MANN“s online US catalogue.
http://www.mann-hummel.com/mf_prodka...11&ktlg_lang=1
Cheers,
SANTIAGO
Old July 3rd, 2011, 07:56 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Unfortunately we no longer live in a time when a company actually produces the product(s) it's name is on. What's worse is that there may be any number of sources for their labelled products. What's even worse is that the quality control on these out-sourced products can vary greatly. Bottom line, don't assume any of them are guaranteed to be top shelf.
One more reason to just change your oil and filter often.
Old July 3rd, 2011, 07:28 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Originally Posted by defeyago View Post
Oil MANN W930/20
Diesel MANN WK842/2
Cheers,
and also MANN Air filter for 300Tdi: C14160
- Charles Eames
Old July 4th, 2011, 12:40 AM
TS888's Avatar
TS888
Tony Sims
1984 110
If you're changing your oil and filter every 3k-4k miles, pretty much any filter is going to be OK. It's a Rover, not an F1 car...
Tony
1984 110 "Smokey" (sold)
Old July 22nd, 2011, 09:23 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I installed a MANN filter. I also went with Blackstone Laboratories for the oil analysis. Highly recommended. Link: http://www.blackstone-labs.com
Very detailed report but here are their comments:
No problems showed up in the initial sample from your Land Rover. All wear in the average range
for this type of engine, which is a very good indication of normally wearing parts. You might normally change
it at 3,000 miles, but the engine didn't mind this 5,500-mile run at all. You could stick with this or even go
longer next time, if you wanted. Universal averages show normal wear after about 3,200 miles on the oil, so
your engine is wearing better than most. Insolubles were low, showing good oil filtration. No fuel or
anti-freeze was found. All in all, a very nice report.
Old July 23rd, 2011, 07:56 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Wix and Baldwin/Hastings still make their own filters.
I'm comfortable using filters that are used by people/companies who's livelihood depends on their vehicles. Truckers, heavy equipment operators, etc.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
300tdi, tdi
Substitution parts: oil filters MonLand Defender Technical Discussions 6 January 25th, 2008 10:12 AM
International HS2.8L Filters DesertRat Defender Technical Discussions 3 August 7th, 2006 11:51 PM
OIL...oil...oil... norros Defender Technical Discussions 20 August 22nd, 2004 01:30 AM
Air filters and a bad fuel tank valve thingy! RickM Defender Technical Discussions 1 August 9th, 2004 03:29 PM
Who wants filters? dmarchand For Sale - Parts 0 May 27th, 2004 12:40 PM
