Filter Mag - Defender Source
Old November 2nd, 2006, 08:44 PM
Defender13's Avatar
Defender13
Mike Lynch
1994 Defender 90 #1017
Filter Mag
Has anyone here ever had any experience with Filter Mag for a oil filter? I had read some positive and negative articles about it but what to see if anyone here had any opinions.
FILTER MAG WEBSITE
Mike Lynch
Old November 3rd, 2006, 01:08 AM
Trevor Tarr's Avatar
Trevor Tarr
Trevor Tarr
1997 D-90 4.6 NAS ST
I'm using one. But I'm also a sucker for bogus gizmos. I have no way of determining if it makes any difference or not. But I figure it's probably not doing any harm.
Old November 3rd, 2006, 01:33 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
I found some extremely strong magnets at a surplus store a while back. I stick one on the lowest point of the oil pan and one on the bottom of the oil filter. I can stick my finger into the oil drain hole and feel the crap accumulated after draining the oil. I remove the magnet and flush the pan. Don't know what the one on the filter does but imagine it has to be catching something.
Old November 3rd, 2006, 10:54 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
I figured that the oil filter does the job already. The oil pan magnet, retrieving the particles is the trick. So if close enough to the drain hole, retrieving by finger and feel seems limited. I'm using the magnet drain plugs, which shows the
metal particles that come out with the plug at oil change.
Old November 3rd, 2006, 11:24 AM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
I have seen the pictures on EE with magnetic particals stuck to the side of the filter, I question that if your motor has that much iron floating in it, that it is about to sh!t the bed anyway.
I do however recoment the magnetic drain plugs for your diff's and transfer case. I had a magnetic plug in my diffs. When I changed out to an ARB there was all sorts of iron on the magnet. The spider gear shaft had shatered. The cool thing was the bearings showed no adverse wear/scaring what so ever.
--Benjamin Franklin
Old November 4th, 2006, 04:23 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Yup got all magnetic plugs for the diffs as well. When I pulled the sump plug, it looked like EE's pic as well.
The particles clumped together were real fine with no roughness when rubbed between the fingers, they are too fine.
I first thought, "holy sh.t " my engine is shaving steel". I have changed oil every three thou.
Old April 12th, 2009, 12:29 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
I'm going to put in magnetic plugs and I see that the ones sold at EE - Land Rover Genuine Parts Magnetic Drain Plug (FTC5208)
https://www.expeditionexchange.com/d...ndexmain.shtml
...also work for the diffs, trans, and transfer case according to a post here on D90:
http://www.defendersource.com/forum/...=magnetic+plug
I didn't see anything mentioned about the main engine oil plug. I forgot if they are magnetic from the factory. I'm pretty sure my 95 didn't have a magnetic one - not sure about the 97s.
Can anyone point me in the right direction on where to fine a magnetic engine oil plug?
Hutch
Old April 12th, 2009, 01:40 PM
The oil filter catches anything large enough to CAUSE wear in the engine, that is it's purpose.
If you are accumulated large enough amounts of iron in the oil to see them, you have serious engine problems or are using very bad oil.
My suggestion to everyone is get an oil analysis every now and then. This will tell you a lot about your engine and how the oil is performing.
Old April 13th, 2009, 08:23 AM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
Good point. You are probably right.
Just thought I'd slap one on if I could find the part as it probably couldn't hurt. I suppose that could be my oil analysis!
New Air filter box for HS 2.8 engine Santiago Defender Technical Discussions 6 November 17th, 2016 04:33 AM
D-90 air filter housing cap needed (horn) arbik Wanted 4 November 30th, 2010 12:45 PM
Oil Filter Craigd Defender Technical Discussions 9 July 26th, 2005 07:06 PM
Air Filter Box Upgrade- Help!! alkhalifa Defender Technical Discussions 59 October 19th, 2004 04:37 AM
Check your trans filter! {manual} Bowtracer Defender Technical Discussions 5 May 25th, 2004 10:32 AM
