Filling a T-case! - Defender Source
Old June 2nd, 2004, 12:41 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Filling a T-case!
My T-case is leaking oil very heavily and I want to refill it for now. After searching it looks like Iím going with 75/90 oil but I have one question though. Where is the fill plug on the T-case, and is there any special tool I need to use?
Old June 2nd, 2004, 01:09 PM
Behind the drum brake, it's kind of hard to get to I use a tube that screws onto the top of the bottle then you can squeeze the bottle to get the oil in the T-case. You just stick a 1/2" drive into the plug on the t-case, like on the diffs.
Old June 2nd, 2004, 01:14 PM
Yousef,
On my 97 ST it is on the back of the t-case right next to the parking brake drum. To open it you need a 1/2inch square drive. It is a tight fit but just loosten it enough that you can unthread it by hand. Goood luck...
Old June 2nd, 2004, 01:21 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
Awesome, found it. Thanks guys.
Now here comes the second question. My T-case is leaking from where the driveshaft bolts to, now I could have a bad seal but then something could be loose in there. Do you guys know the socket size for that big nut in the middle of the drum, assuming that nut holds the drum on right?
Old June 2nd, 2004, 01:43 PM
WBDISCO's Avatar
WBDISCO
Brad Bradford
If it is the front, then i believe it is a 30mm
Old June 2nd, 2004, 01:50 PM
Not sure on size but tork it to 120 ftlbs per manual. It's less then 1 1/4" as thats the biggest socket I have.
Old June 3rd, 2004, 04:17 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I rebuilt a transfer box last year and 30mm rings a bell for the big nuts.
The seals are pretty straight foward to change but check the condition of the collar that it seals onto.
Mike Hammond
Old June 3rd, 2004, 04:21 AM
mikeslandrover
Mike Hammond
I've got some scans of the transfer box (exploded diagrams if that would help
Mike Hammond
Old June 3rd, 2004, 06:32 AM
Berty's Avatar
Berty
Brett Hurrell
D90 Hardtop 300Tdi
Yousef, if you replace the seal make sure you check the transfer box bearing. If thats gone bad it'll knock the new seal out faily quickly.
Sniff my Diff ;)
Old June 3rd, 2004, 01:10 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
i don't think I'll do the seal myself, I just need to make sure everything is tight at the moment. My T-case is leaking like an open drain plug
Old June 3rd, 2004, 03:06 PM
mikeslandrover
Mike Hammond
The box is really easy if it's just seals, I needed to special tools except for a very large pair of circlip pliers
Mike Hammond
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
94 transfer case problems Campbell Defender Technical Discussions 25 March 19th, 2005 12:09 PM
Rover Expedition Case w/ 4 walkie talkies jack frisch For Sale - Parts 0 February 27th, 2005 03:24 AM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
