Fiberglass top tailgate window gas struts part# - Defender Source
Old December 8th, 2008, 03:08 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
The rear window gas struts on my fiberglass top needs more than viagra. I've done a search on here and came up with replacement parts list. Part number 752940 available from JWF Technologies.
Anyhow, I went to verify the actual struts on my top and there is no number that coincides with that part number.
I know the actual strut is made by Lift o mat, but the part numbers have been worn away somewhat.
I think it reads 90033DB 0100N 45/94 1/5 but its a really tough read.
Just wan to confirm that part number (752940) is correct from the list before I actually order from them. Anyone here order gas struts from them?
Thanks in advance!
Name:	gas strut capture.png
Old December 8th, 2008, 04:29 PM
Check the price, they're pretty cheap at mcmaster.com - I think you need 20 or 30 pound struts. You just have to measure them, and I think you ends will swap.
Old December 8th, 2008, 06:24 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Thanks for the link and info. I'll check measurement tomorrow. Man it got cold out there!
There is this place near me that I might check out http://www.jjtrailers.com/ tomorrow.
I remember getting some replacement gas struts for a truck cap a few years ago.
Might just take the d90 there and have them look at it and see if they have something in stock.
Christmas shopping in the 90 tomorrow! Gonna have to take the bench seat out!
Braved the cold and measured 11 1/2" housing barrel, 23 1/4" +/- fully opened. Looking at the McMaster website, I'm not sure if I theres a match. I'll do a search for lift o mat and see if there's a match with those dimensions.
Old October 24th, 2010, 06:53 AM
maleger
Marc-Andre Leger
Had to research this, so here are the part numbers from http://www.mcmaster.com for future reference.
The gas struts are 2x 9416K2 in 30lb strength
4x 9416K86 M6 nylon ball socket fittings
2x 9512K12 304 stainless ball brackets
1x each (left and right) 9512K16 and 9512K17
I found this information on http://www.myrovers.com/?cat=4
Old October 27th, 2010, 08:21 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Beware . . .
Those gas struts are about an inch too long, overall, when I tried to install them. I just bought a pair of them and they are too long and you can't close the lift gate. I would guess about a half inch less total length, and a half more on the stroke and it would be fine, so an inch overall. They measure to the base of the threads, not to the center of the opening when the adaptor is on, which accounts for the extra inch.
Old October 27th, 2010, 10:47 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
I ended up buying them from JWF Technologies after going through the same fitment problem - this is even after going to the place I mentioned and them taking measurements.
Anyway JWF was easy to deal with and they had the gas struts in stock.
fiber, fiberglass, fiberglass top, gas, glass, part, tailgate, window
Removable Fiberglass Hard Top Stewperformer Wanted 0 March 14th, 2006 08:22 PM
Fiberglass Hard Top, Fan Clutch and Front QT Diff Guard cgalpin For Sale - Parts 10 January 6th, 2006 10:45 PM
Fiberglass Top Needed in Colorado boshea Wanted 3 December 8th, 2005 01:24 PM
ST Window and tailgate? mlw911 Defender Technical Discussions 5 October 25th, 2004 06:27 PM
wind noise with fiberglass top GliderKing Defender Technical Discussions 4 October 10th, 2003 04:13 PM
