Fiberglass top reinforcement - Defender Source
Old July 4th, 2004, 01:05 AM
Cyborg
Larry Walton
'97 D-90 ST #2066 UK 4X4
Hey bros, I just bought a fiberglass top for my D90. It was a long ordeal finding one that was not cracked or broken in some way. This one is in good shape but I have a concern. Seems like they all develop cracks in certain areas over time. If you were me would you consider installing some sort of reinforcement in certain areas before the apparently inevitable damage occurs? Maybe a little fiberglass resin appropriately located might be in order?
Suggestions, ideas??
Cyborg
Visit the Land Rover Beer Bar,"The Best Beer Bar X Far!"
Old July 4th, 2004, 04:37 PM
boshea's Avatar
boshea
Brian OShea
1995 Defender 90 ST
I just did some reinforcement work on my top with some resin and fiberglass sheeting...it works really really really well. However, it can be a little sticky and very toxic...so be careful handling the stuff.
Good luck!
Old July 5th, 2004, 06:39 AM
Cyborg
Larry Walton
Brian, Can you be more specific about where you reinforced and if it was already broken or if you forsee it breaking?
Larry
Old July 5th, 2004, 08:54 PM
Hey, on the side pieces to my fiberglass top there is a 1"x1" square alluminum bars mounted under the window that run the lenght of the window. It came that way when I got it.
Old July 7th, 2004, 05:05 PM
boshea's Avatar
boshea
Brian OShea
1995 Defender 90 ST
I also have the supports. Although the only run under the length of the window. You may want to add additional support to the thin areas at the corners...where the sides secure the windows in place. This is a very vulnerable stress point.
fiber, fiberglass, fiberglass top, glass
Fiberglass top install question d90_1372 Defender Technical Discussions 7 September 14th, 2009 11:07 PM
FS: NAS Fiberglass Top, NYC area NASD90 For Sale - Parts 1 September 1st, 2004 05:17 PM
Differences between metal and fiberglass top jaherring Defender Technical Discussions 5 June 19th, 2004 05:59 PM
Fiberglass top for Soft Top? boshea For Sale - Parts 1 April 19th, 2004 04:23 PM
Fiberglass Hard Top $1300 cbkearney For Sale - Parts 1 November 3rd, 2003 04:17 PM
