Fiberglass Hard Top Window Seals - Defender Source
Old April 25th, 2009, 09:12 AM
Grover's Avatar
Grover
Question Fiberglass Hard Top Window Seals
Is it possible to replace all of the window seals (alpine, sides, rear) on a Fiberglass Hard Top while it is installed on the truck? Has anyone done this? Any advice?
Cheers...
Old April 25th, 2009, 09:37 AM
Sure, its quite easy. Just buy a YA208A from Blue Point (a Snap-On brand) for like 20 bucks and you'll be done in less than an hour. Just lube everything up good with Windex.
Old April 25th, 2009, 11:35 AM
Grover's Avatar
Grover
Thumbs up
Thanks JimC. So this can be done externally? No need to access the window seals from the inside? I was concerned about the rollcage interfering. I am also concerned about cracking the fiberglass.
Cheers...
Old April 25th, 2009, 11:40 AM
I've done it, but it does depend on whether or not you want the lock strip on the inside or the outside. Lock strips have always been on the outside for alpine glass and don't seem to be much problem. That being said, I have always installed the side windows with the lock strip on the inside because I like the flush appearance on the outside.
For myself I would take off the side panels and make life easy for installing the lock strip on the inside. You can leave the roof panel in place, just unbolt the sides, push the top up, support it and extract the sides.
Old April 25th, 2009, 01:56 PM
Grover's Avatar
Grover
Thumbs up
Good info...can you school on the lock strip? I take it the lock strip is the more pliable side of the seal , and the side that requires access?
Cheers...
fiber, fiberglass, glass, hard top, seals, window
Window seals for Fiberglass Hard Top (wanted) wildenbeast Wanted 1 November 1st, 2005 10:55 AM
Hard Top for sale Mark Cama For Sale - Parts 0 August 31st, 2005 09:19 AM
FS: NAS Fiberglass Top, NYC area NASD90 For Sale - Parts 1 September 1st, 2004 05:17 PM
Fiberglass Hard Top Joe P Misc. Chit-Chat 9 June 24th, 2004 05:47 PM
Fiberglass Hard Top $1300 cbkearney For Sale - Parts 1 November 3rd, 2003 04:17 PM
» Defender Registry
#2983
highatp
Baloo
phreeb
Add your Defender
