Fender Flares - Defender Source
Old November 14th, 2009, 04:37 PM
Grover's Avatar
Grover
Unhappy Fender Flares
I used "Forever Black" on my fender flares a while ago...long story short...they now look like sh!t, i.e. stained with streaks and blotches (I should have left well enough alone) Has anybody experienced this? Can I un-do the damage?
Cheers...
Old November 14th, 2009, 05:46 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Yeah, get a body shop to refinish them though. Might as well go body colour at the same time. Painting abs/PVC or whatever plastic they are is tricky but given how much of a modern car is plastic...
Old November 14th, 2009, 05:54 PM
I would take them off and soak them in soapy water for a day or two. If that doesn't work then I am not sure. Are all 4 bad?
Old November 14th, 2009, 05:58 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
You can easily redo them inexpensively yourself. Go to a auto body paint and get degreaser/dewaxer Wipe the flares down with the degreaser, using a lint free rag(make sure to wear chemical gloves and a respirator). Then use matte or gloss black spray paint specifically made for auto abs and other automotive plastics. I did it myself over a year ago(my wheel arches were 25 years old,1984 d-90). My wheel arches were really bad. They look great now. After a year there are no streaks, peeling, fading, etc. The key is to use the right products specifically made for automotive use. Don't use some paint product from your local home center or pep boys that claims to be ok for plastic, etc. Get the stuff that body shops use from a professional supplier.
Old November 14th, 2009, 06:26 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Do not paint them till you try the following first, it made mine look like new even after the detail shop put some thick tire gloss stuff on them. Also did the same thing on my 1984 and it made them look like new.
Concentrated Simple green and a wash cloth or soft brush, let the simple gree sit on the flare for a little bit (do not let it dry), then scrub it. I would suggest removing the flares if possible but you could always try it on a small area to see if it will work prior to removing them.
Fender flares Hazard Wanted 1 June 11th, 2009 03:42 PM
D90 Precut Fender Flares for 35" Tires taoseno Wanted 0 May 4th, 2009 01:18 PM
D2 Fender Flares 4 Sale! RoverChic For Sale - Parts 1 January 21st, 2006 09:37 PM
defender fender flares WhiteD90 Wanted 2 June 9th, 2004 08:19 AM
D90 fender flares for sale Chris Cox For Sale - Parts 10 April 23rd, 2004 02:42 AM
