Fender flare push pin removal - Defender Source
Old December 2nd, 2012, 07:39 PM
So after breaking a few of these trying to remove, i can't figure out how to get them off without breaking them. Is there a way, or do you just replace them with new ones afterwards?
Old December 2nd, 2012, 07:52 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Use a small screw driver or dowel and push the pin all the way through. Once you push the dowel through the head will pull right out. The little pins will fall and you need to track each one the best you can. You should be able to find 90% of them.
Old December 2nd, 2012, 08:19 PM
Brilliant...thanks! Will give it a shot, seems logical my brain just wasn't there yet.
Old December 2nd, 2012, 10:22 PM
Abrooks's Avatar
Abrooks
Tony Brooks
When I swapped out the flares on the old 110 I wound up buying a big bag of new ones from RDS, made life much easier using new ones to reinstall.
Old December 2nd, 2012, 11:02 PM
I've got a small drift set that should work, but I ordered a bunch from LRSeries.com along with a bunch of other stuff I've needed.
Old December 2nd, 2012, 11:18 PM
My 2˘ is once you get them off, leave them off.
-Jeff
The flares?
Old December 2nd, 2012, 11:54 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
yea.
-Jeff
Old December 3rd, 2012, 04:07 AM
Or
http://www.harborfreight.com/push-pin-pliers-67400.html
Old December 3rd, 2012, 09:55 AM
I have 10 of these new at home, Jason. If you need any to replace a few broken ones, let me know and I'll give 'em to you
I need front winsheld,right fender black flare, rear door glass. Vadim Wanted 2 July 23rd, 2004 11:47 AM
LH front fender flare!!!!!!!!!!!! Shane@EVS Wanted 1 July 16th, 2004 03:33 PM
Front LH matte black fender flare Shane@EVS Wanted 0 May 27th, 2004 09:57 PM
Looking for stock fender flare vnrover Wanted 5 December 7th, 2003 02:58 PM
» Defender Registry
Summer
StuartL
Tina
UtahD90
Add your Defender
