Fender Flare buttons - Defender Source
Old June 2nd, 2011, 01:10 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Does someone have an alternative to the plastic buttons? Was thinking a screw with a washer?
Old June 2nd, 2011, 01:14 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
rivets
Old June 2nd, 2011, 02:40 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I'd stay with the buttons. I broken button is easier to replace than a broken wheel flare. Rovafarm has the buttons.
Old June 2nd, 2011, 02:56 PM
TS888's Avatar
TS888
Tony Sims
1984 110
The buttons are more likely to let go and let the flare rip off instead of tearing the wing panel, too. If you hook a tree with a flare that's riveted on, the wing is going to be thrashed.
Tony
1984 110 "Smokey" (sold)
Old June 2nd, 2011, 03:02 PM
Naplm00
Matthew
most napa and autopart stores carry what they call "Christmas trees"
https://www.kimballmidwest.com/catal...ges/10-592.jpg
usually about 5 bucks for a bag of 20 or so, they come in removable and pry out style like above. Cheap and effective
Old June 2nd, 2011, 03:05 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Are you talking about something like this?
http://www.pro-dec.com/screw-caps-sc...2-12-snap-caps
I've used these on my Roccia fender flares (DI) and roof rack bolts.
John C.
Old June 2nd, 2011, 03:19 PM
You can get something similar from Home Depot... They are like $5 for a bunch of them. But, you will need to paint them black, the come white.
Old June 2nd, 2011, 03:21 PM
JohnC
Now that you mention a hardware store, you can also get them at ACE Hardware and they have them in black.
John C.
Old June 2nd, 2011, 03:49 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
http://www.harborfreight.com/catalog...=plastic+rivet
Here is what I have seen used... Works just fine.
Old June 2nd, 2011, 04:07 PM
97-D90-736
Nick Vogel
Thanks. I was just trying to find something that is easy to take off and on. Now I know I can use the hardware store alternative, I wont be so pissed off when I break the ones that are in there.
Old June 2nd, 2011, 04:15 PM
tjfslaughter
thomas
Burbon
to take the ones off that come from harbor freight all you do is use a center punch and tap them and they pop right out. They are one time use only...
Old June 2nd, 2011, 07:04 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
I use the button but instead of using the little plastic dowel I use a stainless screw,That way if you need to remove it later it is a breeze
Old June 3rd, 2011, 01:39 AM
You can use them again if you salvage the plastic rowel and the fastener doest break. On newer ones it's easy to reuse them. If they are old and brittle then you can usually reuse maybe 50% of them.
Old June 3rd, 2011, 09:28 AM
97-D90-736
Nick Vogel
That is genius. I will look into that. I take it its, a fairly small screw?
Old June 3rd, 2011, 04:30 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
I would guess a #8 oval head
Trade: Front fender flare! TwisteD90 Wanted 12 September 25th, 2005 11:47 PM
I need front winsheld,right fender black flare, rear door glass. Vadim Wanted 2 July 23rd, 2004 11:47 AM
LH front fender flare!!!!!!!!!!!! Shane@EVS Wanted 1 July 16th, 2004 03:33 PM
Front LH matte black fender flare Shane@EVS Wanted 0 May 27th, 2004 09:57 PM
Looking for stock fender flare vnrover Wanted 5 December 7th, 2003 02:58 PM
