Fender Flare Attachment - Defender Source
Old June 4th, 2008, 11:28 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Installing new flares and it appears that there's not a snowball's chance in hell that the original plastic push bolt connector thingys are going to survive removal. What have people used successfully to attach flares?
Old June 4th, 2008, 11:29 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I think George has them at RDS.
Old June 4th, 2008, 12:13 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Aren't they just regular plastic rivnuts that you can buy at autozone?
Robert Deniro
Old June 4th, 2008, 12:50 PM
I bought some at Lowes... They were not black, but they worked very well. A large box was like $4.00. I used a little sharpy to blacken the heads.
AutoZone has them too, and they are black, but they a small box is $4.00.
Old June 4th, 2008, 01:09 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
I got mine from George.
Keith
Big, Red and ... aaa Red..
Old June 4th, 2008, 02:42 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
You should be able to salvage 90 to 95% of them when you remove them. Use a small diameter drift to push the pin all the way through and look for it as it falls out. The rivit will pry out pretty easy at this time. Some of the pins will get stuck in the various nooks and crannies of the fender but some careful feeling around and you will find them. Push the pins back into the rivits and reinstall.
CB
Old June 4th, 2008, 04:27 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Thanks, Chris, I'll give that a try.
Old June 4th, 2008, 04:38 PM
I drilled the damn heads off and started fresh. I bought replacements christmas trees @ the ace hardware up the street. Exact same part 15 cents each
Old June 4th, 2008, 11:00 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Doug - I wonder if you're talking about the same fasteners? I've removed my fender flares several times, and they really do come out quite easily as Chris mentioned. Once the center pin is popped out, there's nothing holding them in. I've only replaced them when I've lost the center pin.
Old June 5th, 2008, 01:48 AM
pendy's Avatar
pendy
jim pendleton
89'd90
I have fought the UK trucks flares fasteners and had good luck, mostly, removing NAS fender flare fasteners. The correct part is inexpensive and a better fit usually.
legend in my own mind
Old June 5th, 2008, 07:56 AM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
Heck the easiest thing to do is what I have done, Drive the the pins out and go out and but some small stainless steel screws. Screw them in. that way you can remove the flares easily if need be.
Old June 5th, 2008, 11:05 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Yes good point. I do that too with the orphaned pieces I loose pins for. Can't say I bother with stainless. The orphaned ones go on the 'beaters'
Old June 5th, 2008, 11:32 AM
on my NAS 90 there were no center pins just a plastic push in christmas tree type that are hard to salvage. The center pin/expanding type I have not had the pleasure of working with.
Old June 5th, 2008, 06:25 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
I'll have to check Sheki's truck to see if he has any orphaned fasteners on it
Old June 7th, 2008, 02:34 PM
Abrooks's Avatar
Abrooks
Tony Brooks
CB
Worked perfectly, thanks for the pointer!
ac
Trade: Front fender flare! TwisteD90 Wanted 12 September 25th, 2005 11:47 PM
I need front winsheld,right fender black flare, rear door glass. Vadim Wanted 2 July 23rd, 2004 11:47 AM
LH front fender flare!!!!!!!!!!!! Shane@EVS Wanted 1 July 16th, 2004 03:33 PM
Front LH matte black fender flare Shane@EVS Wanted 0 May 27th, 2004 09:57 PM
Looking for stock fender flare vnrover Wanted 5 December 7th, 2003 02:58 PM
