Feeler for wheel spacers - Defender Source
Old February 5th, 2009, 05:43 PM
johnpiero
John Brancato
none
To help fund my d-90 project I had an idea to make some extra money:
When I removed wheel spacers off my '94 d-90 I couldn't believe how easy they are to make. I will be making another set for myself (I'm a machinist at a company serving up-to-aerospace quality...more than sufficient).
If anyone is interested, let me know...they would cost approx $75 for 2 spacers.
There's a catch: I'm not an engineer or a corporation so i take no responsibilty/liability!
Sorry, one more catch: you'd be on your own for the hardware (studs and nuts). I would only make the aluminum spacer out of aerospace-grade aluminum, pre-tapped for the studs.
Old February 5th, 2009, 05:49 PM
why not make the back of the spacer so that a normal rover stud could be pressed in ? I woud be interested in a pair if I wouldn't have to hunt down custom hardware to make them serviceable.
I would also be interested in some rear sway bar mount spacers made from aluminum say 1 inch thick. Simple solid rectangle of aluminum with four holes for the sway bar bracket bolts, the spacer should be te same size as the face of the mounting bracket. This would serve two purposes, space the swaybar geometry downward to correct for lifted trucks and also to beef up the week frame bracket.
Old February 5th, 2009, 06:23 PM
I am in for a full set (all 4 wheels)
Old February 5th, 2009, 08:04 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I might be interested, pending 3 things.
If they are done so rover studs can be used, which are a press fit, preferably the longer studs so there more meat of the space holding them.
What alloy are they made from?
Are the hub centric or lug centric?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 5th, 2009, 11:12 PM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
For that price (150$ for 4), I'm in
'92 Disco truggy (42"s, ZF, dual cases, ARBs, 30 splined, OMEs, Optimas, Warns, Bead-Locked)
'04 D-90 TD5 ST (33"s, tuned, caged, 1/2 top)
'84 Rangie 2 door classic (32"s, OME, ARB bar & M8000)
'04 Disco II stock
'07BMW G650X Challenge (farkled)
Old February 6th, 2009, 03:21 AM
these com in different thickness's how thick would yours be ?
Old February 6th, 2009, 06:45 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I'm out!
Semper Fi!
Old February 20th, 2009, 07:00 PM
johnpiero
John Brancato
none
I decided to sell the wheel spacers (see For Sale Section)....I chickened out at the advise from others due to too much liabilty.
However, I'm still looking to make some extra money and take advantage of the machine-shop, so if anyone is interested in getting something fabricated please let me know.
Old February 20th, 2009, 08:13 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Rover studs are about 5 buck's each, seems that premade ones aren't that overpriced.
ac, wheel, wheel spacer
Safarigard 1" aluminum wheel spacers dannykkim Defender Technical Discussions 1 March 7th, 2005 04:29 PM
1.5" spring spacers lwg Wanted 0 February 1st, 2005 02:56 PM
Wheel spacers artm Defender Technical Discussions 4 December 13th, 2004 10:44 AM
wheel spacers krisp For Sale - Parts 15 November 30th, 2004 11:03 AM
Wheel spacers Dfndr90 Defender Technical Discussions 1 September 9th, 2004 12:22 AM
