Feeding the leaky beast - Defender Source
Old January 7th, 2016, 08:36 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
1988 D110 300tdi/R380
Just curious what brands/weights of fluids are people putting in their vehicles here in the US? I'm particularly interested in collecting the following information for those that would like to share.
Engine type, oil recommendation
Transmission type, oil recommendation
Transfer case type, oil recommendation
Axle type, oil recommendation
etc.
With my vehicle, I truly have no idea what's good fluid for my configuration of:
300tdi
R380
LT230
Salisbury
Any recommendations?
Old January 7th, 2016, 09:17 PM
Rotella 15W40
Redline MTL
Lucas 80W90
Lucas 80W90
etc.
basic green coolant, Castrol GT LMA for clutch/brakes if possible....otherwise the newer Castrol version is fine.
300tdi
R380
LT230
Salisbury
See above...
Old January 7th, 2016, 09:59 PM
[QUOTE=TheOneTen;704222]Just curious what brands/weights of fluids are people putting in their vehicles here in the US? I'm particularly interested in collecting the following information for those that would like to share.
Engine type - Any XW40 diesel engine oil.
Transmission type, Low viscosity manual transmission fluid
Transfer case type, Any XW90 gear oil
Axle type, Any XW90 gear oil
All in the owner or workshop manual.
Old January 8th, 2016, 12:27 AM
Engine type: Rotella Synthetic 15W40
Transmission type: Honda MTF
Transfer case type: Mobil 1 Synthetic 90W
Axle type: Cheapest 90W available
Old January 8th, 2016, 08:46 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Not sure how available the Castol GT LMA is. My local carquest only stock the Castrol DOT 4 now. I think it supersedes the GT LMA. I've been running it for a while with any issues.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old January 8th, 2016, 08:48 AM
Agreed which is why I put the "newer" version should be fine. BUT...my local Napa has had the smaller bottles on the shelf, and the last time I was there was actually able to get me a larger bottle of the LMA (amazingly). Not sure if they're just flush with stock, but I was pretty happy to get it!
Old January 8th, 2016, 08:51 AM
waveridin1959
Brian Jones
1995 D-90 ST #2892
I am curious what the differences are. You can run any fluid through rovers, but its particular on brake fluid for whatever reason.
Lav - I just saw you put the "newer version" as well. My bad for jumping the gun.
1995 Defender ST
1996 Discovery SE7
Old January 8th, 2016, 09:59 AM
Brake fluid does not matter. That is just a hold over from old series trucks. Any "Defenders" use the same seal materials as every other modern vehicle.
Old January 8th, 2016, 10:20 AM
I'm still brainwashed for LMA . Or Castrol. Old habits die hard. But you're right, probably a bigger deal in the Clutch Master than it is for the brakes...but I switched to the Dorman Clutch Master anyhow so I can run pretty much used dish water in it now and it functions fine without the fluid turning into a cloudy gray solution after a month (which the old Rover MC did anyhow even when I ran LMA).
Quite the beast, not mine jayz The Flea Market 1 August 14th, 2012 09:02 PM
1995 Range Rover Classic LWB..Off Road Beast...Runs Strong...$4000 obo howido213 For Sale - Vehicles 7 August 5th, 2011 10:20 AM
beauty and the beast ditskovich Misc. Chit-Chat 5 April 6th, 2011 06:31 AM
care and feeding of roll cage foam bearskinrug Defender Technical Discussions 1 January 15th, 2011 03:06 PM
Saw this little beast on Ebay today WCURoverD90 Misc. Chit-Chat 7 March 23rd, 2005 02:09 PM
